adjusting front height
Hello
I've got some troubles to ajust the front height on my '72 S
the screws to set the height (front) are on the max position, but i can't lower more the car. (still 2 inches between tire and body)
I have bilstein "track" shocks in boge struts.
Shall i reindex the bars or wait to drive the car till it lowers a bit ?
regards
Philippe
Old 05-08-2007, 08:08 AM
dweymer's Avatar
I don't think it will settle that much, since the fronts are easy, re-index them 1 tooth and drive that to see where it leaves you. Also, be sure to set the adjustment screw around the middle, that way you can go either direction when it's settled.
Donnie
Currently Porsche-less.....
Old 05-08-2007, 08:26 AM
Somatic Negative Optimist
Gunter's Avatar
You answered your own question:
Gas-pressure shocks will settle a little more after you lifted the car.
If not, then re-index the front T-bars.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
thanks for the quick feedback
do you remember a post where it's explained ?
Philippe
Old 05-08-2007, 08:30 AM
safe's Avatar
Just remove the adjuster screw and pull of the end cap (that the screw goes throu), reset the end cap in another position that alows a lower ride hight (anticlockwise I belive on the drivers side.).
Magnus
Old 05-08-2007, 10:57 AM
