Front turn signal light function question
Hi Folks,
I have a quick question. I've updated my '80 SC with C2 bumpers and lights. Do the front turn signals have a built in parking light function on the normal SC's and Carerra's or is it purely a turn signal light that is only on/off (no parking light "dim" function when lights are on)? I'm assuming that the signals purely flash on/off and the parking light function is a separate connector/light. Can you confirm? Thanks in advance.
99 996 C2 Black, MY02 wheels, Aerokit Way too much fun! |
The front turn signals on the SC have a dual filament bulb. One is the parking light, the other the turn signal. That way you can have the parking lights on and have a turn signal function at the same time. If you are using the C2 lights in your conversion I would think they would work the same way. Just remove the lens and look at the bulb.
Hope this helps.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Thread Tools | |
Rate This Thread | |
