sbrown.nw's Avatar
caliper upgrades for my '72 T
Hello,
I was wondering what calipers I can purchase to upgrade my factory ones on my '72 T. I think the previous owner went to Carrera rotors (if that is possible) and the brake pads only seem to cover about 3/4ths of the rotor surface area. As far as I can tell, I have factory '72 struts (they are black if that helps). What calipers could I go to for a bolt on upgrade?
TIA!
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 05-17-2007, 01:48 PM
Bill Verburg's Avatar
Originaly that car came w/ M front and rear.
If you still have the M front struts the first thing to do is replace them w/ A or S struts. The difference is in the caliper mounts
3" on M
3.5" on S or A
Bill Verburg
Old 05-17-2007, 02:49 PM
sbrown.nw's Avatar
My local shop said I could go with 993 or maybe 964 front calipers (non-turbo) with minimal machining after my 17" rim upgrade without having to replace the struts. Anyone done this? If so, anyone know of some of these available?
Thanks,
Scott
Old 05-17-2007, 08:35 PM
