amersbell's Avatar
Unhappy Where is the Oxygen Sensor Connect?
I have an 81 SC. I am replacing the cat with a bypass because it is clogged and old. I was told by previous owner that the oxygen sensor had been deleted, but it is still in the cat. I don't think the wire went to anything. Where does the oxygen sensor connect in the engine compartment and how do you know if they have really deleted it correctly?
Chris Bell
Confused owner with more 911 questions than answers......and no one to ask in West Texas.
1971 Targa, 1981 911 SC Targa, 1995 993 Coupe
2008 Cayman
Old 05-21-2007, 05:02 PM
RETIRED
Joe Bob's Avatar
Lookin at the motor...there's a port on the left side fire wall.
2012 ML350 3.0 Turbo Diesel
Old 05-21-2007, 05:27 PM
amersbell's Avatar
But where does it connect to the motor or CIS?
Chris Bell
2008 Cayman
Old 05-21-2007, 05:29 PM
sjf911's Avatar
The wire runs to the Lambda control unit under the passenger seat in a large wiring harness that goes through the fire wall above the right side of the shift-coupler housing.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 05-21-2007, 06:08 PM
amersbell's Avatar
How do you know if it was disconnected properly (if there is such a thing)?
Chris Bell
2008 Cayman
Old 05-21-2007, 06:54 PM
Now in 993 land ...
aigel's Avatar
Well, it is not correct to disconnect it, unless you go back to a pre O2 sensor CIS setup. You will want to run the O2 sensor in your bypass pipe. If you just unplug the sensor, your cold start and cold idle will be pretty bumpy and you mileage will suffer as well. I had my O2 sensor disconnected at times on my SC, thinking that it made a difference on the butt dyno, but if you read about it, it makes no sense as at WOT the O2 sensor is not taken into account. Maybe the throttle response is a bit snappier, but that's only "maybe"...
George
George
81 SC (sold)
Old 05-21-2007, 08:34 PM
amersbell's Avatar
Is there something that would tell me if it had been backdated to pre 02 sensor time?
Chris Bell
2008 Cayman
Old 05-22-2007, 11:26 AM
Now in 993 land ...
aigel's Avatar
Highly unlikey that someone would go back to non O2 sensor setup. But one thing that would be missing is the electronic control box under the passenger's seat. There are other components, like the frequency valve that should not be there. I am not positive where the frequency valve is located on the 911 CIS but you could do a search on that.
Honestly, I don't think it is a good idea to go pre lambda sensor if it is all already there. Most bypass pipes come with a bung for the O2 sensor already installed. If you don't have it, it's a matter of $20 at your nearest muffler shop ...
George
81 SC (sold)
Old 05-22-2007, 02:22 PM
amersbell's Avatar
George,
Thanks, I will keep looking. I do have the lamda box under the seat. I'm guessing it was just unplugged.
Chris Bell
2008 Cayman
Old 05-22-2007, 03:54 PM
