Registered abUser
TerryH's Avatar
Kind of amazing that that clock still works on my '81, but even more amazing is it keeps perfect time. It must of been replaced at some point.
'81 911SC Coupe SOLD
Old 05-25-2007, 03:03 PM
Registered abUser
TerryH's Avatar
Originally posted by k911sc
are you guys kidding on the white hand?
i assumed it was a rallye inspired thing? if you pull the knob out you can move it around the face and "mark" a time. as an enduro rider from way back time and distance can reveal average speed.
you guys really are joking about the white hand right? my take may suck,,, but i had one.
T$
You think that's weird, I found that to check the oil I had to a remove a cap that read 710!! Strange, but true!
Old 05-25-2007, 03:06 PM
slodave's Avatar
Originally posted by silverc4s
Over the years the clock's lubricant hardens and is the primary reason that the fuse link blows and the clock stops. If you are making on run again, you should clean and re oil it before repalcing the fuse link, or you might eventually get an unwanted electrical event behind your instrumnet panel...
I took mine apart last night. I have the neat-hard-to-remove Quartz clock. I did get the clock apart and when I rotate the gears, I can feel some hesitation - like a small grain of sand is stuck in a gear. I was going to try and clean the gears and re oil.
Dave
Old 05-25-2007, 03:45 PM
that makes no sense to me. if the lubricant hardens all it would do is stop the spring that makes it run the fuse link is only activated in the process of rewinding the spring so if the clock slows or stops it has no effect on the process of rewinding the spring which happens in a split second when the points touch. I don't think you will have any electrical event when you hard wire and put a .75 amp in line fuse right before the clock. Maybe other clocks are build different then mine but I'm sure thats how mine works. On the other hand my clock is running twenty minutes slow every two days so if the adjustment screw on the back of the clock will not correct I'll clean and reoil. i agree that is way his clock would stop on a cold day but i don't think his fuse link is blown or it would not restart.
Old 05-27-2007, 12:41 AM
dave on a mechanical clock like mine I don't think i would ever turn the gears by hand as that very likely can damage something it take s very little energy to keep the osilation (spelling i know is incorrect) of that little wheel going think of a wrist watch not much force winding the spring on the knob. swiss clock were known for workmanship not brute force. Just think thats a bad idea.
Old 05-27-2007, 12:52 AM
