Replace Decel valve on 1982 SC
Does anyone know approximately how much time is involved in replacing a Decel valve on a 1982 SC? Is the engine pulled out of the car for this procedure? I'm trying to estimate what the repair bill will be. Thanks.
Craig 1999 Porsche Carrera 2003 Porsche Boxster 2003 Porsche Boxster S |
Registered Usurper
Mine's disasbled , took about 10 seconds (I didn't personally do it so I can't tell you how) - can't stand the slow drop in revs between shifts. Much more fun to shift without it interfering (better enable to get it smogged though, since it's there for emmissions control on decelaration).
I think there's a "plug it with a golf tee" fix - try the search button.
'82 SC RoW coupe |
Somatic Negative Optimist
Craig:
Why does your Decel Valve need replacing? What are the symptoms? It's a little hard to reach behind the FD but should be doable. Some may do a partial drop?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Revs don't drop. Hunting idle.
First thing I would check is the Auxillary Air Regulator (AAR)
That's the one with the electr. wiring to it. Make sure it gets 12V when running. It's easy: When cold, the "half-moon" is open, after running for about 2 minutes, the heater element inside closes the opening. If the AAR works, I would move on to the AAV and Decel Valve. As for hunting: That's a mixture issue. Of course, unless the AAR, AAV and Decel Valve work properly, you cannot really get it down to 900 RPM to set the mixture or timing. I hope the shop will know for sure where the failure is and not just replace parts until the problem goes away.
I have a decel valve (and the rest of a CIS system) I recently removed from a 82 SC for an EFI upgrade. Send me a PM if you're interested in anything.
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV Last edited by wswilburn; 05-23-2007 at 09:43 PM.. |
