915 Question - what have I done?
Ah stupid mistake I made while changing my tranny fluid. I took out a bolt on the right side, that had a spring behind it. It was the bolt, a washer and this spring in the hole. The spring never came out. Anyways, did I mess something up with my reverse. It seems to drive the same 1 - 5. Doesn't like to go into reverse with engine running. Not sure if this is related, it has acted funny in the past going into reverse.
Any suggestions? Not that big of a deal I think. Just don't put in reverse while engine running.
Thanks,
77 Carrera 3.0
Old 05-25-2007, 08:16 PM
That is a detent spring for your shift rods. As long as nothing fell out and you put the plug back in with the spring you don't have a problem. There is a ball in there the spring pushes on and the ball goes into a detent on the shift rod to make it stay in place when the car is in gear.
-Andy
Old 05-25-2007, 11:05 PM
Irrationally exuberant
ChrisBennet's Avatar
-Andy
Actually, it's not really a "ball", it's pill shaped on a 915.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-26-2007, 05:14 AM
Slumlord
Porsche_monkey's Avatar
-Chris
Actually, it's not really a "pill", it's capsule shaped on a 915.
Old 05-26-2007, 07:09 AM
Immature Member
dentist90's Avatar
Not going into reverse without grinding is a sign that your clutch isn't fully releasing. Check on this... sometimes a simple adjustment at the clutch pedal.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-26-2007, 10:08 AM
thanks all.
77 Carrera 3.0
Old 05-26-2007, 06:10 PM
