-   -   Need pics of Flowmaster installs on 3.0 Engines (http://forums.pelicanparts.com/porsche-911-technical-forum/348650-need-pics-flowmaster-installs-3-0-engines.html)
rennch 05-26-2007 09:16 AM
I'm doing a Flowmaster 80 Series (a la Jack) for my RSR'ish conversion, and I'm probably taking the car next week to the muffler shop. I want to come armed with good pictures to give the guys so they know how the install is supposed to go. It would be a dual in/dual out install. 3.0 motor with early headers. This is what I've got at the moment:
http://forums.pelicanparts.com/uploa...1180199790.jpg
Thanks all...
rennch 05-26-2007 09:17 AM
I should mention that I have already notched out the RSR bumper for the tips...
89911 05-26-2007 10:13 AM
http://forums.pelicanparts.com/uploa...1180203037.jpg
I'm not sure if this is the same, but the Magnaflow I have is set up this way. Primary tubes dump into the lower set and the top tubes come down to the exhaust tips. The guy I took it to used all stainless and bumped the primary outlets off the SSI's up to 2.5 to match the flowmasters. From then on its a straight shot with no restrictions. He may need to make a custom hanger to support the muffler at the middle. Overall, a great setup.
SCWDP911 05-26-2007 11:31 AM
sub'd - looking for 1 in 1out versions as well on my end...
mb911 05-26-2007 01:12 PM
man if you thought the M&K was loud hang on to your hats for a flowmaster.. Mine on a 3.0 was wicked compared to the M&K
SCWDP911 05-26-2007 05:02 PM
Man, really... I think Jack Olsen said that a Flowmaster was a little more subdued... Maybe I should try the gutted stock first.
Anyway, thanks for the tip Ben. Someone just got a screamin deal on one of your 2in 2outs on evilBay. $200 I think with the shipping.
DanielDudley 05-26-2007 05:15 PM
I am removing mine this week, as I cannot drive for more than 20 min. without getting a headache. It sounds great for a few, and now I bring along the ear plugs. I work with power tools BTW, so I am not a wuss when it comes to noise. I managed to ignore it for a long time, and then I started driving around it. Not too bad on the highway, but that was the only time .
PO said it was really flowing too well for optimum. Mine is a 2 in 2 out. Let me know if you want it. Cheap.
rennch 05-26-2007 05:54 PM
Daniel,
Is it a flowmaster 80 that you have? Got a pic of it?
rennch 05-26-2007 05:56 PM
V8-Ranch...I think one of the advantages of the flowmaster (or any of them, really) over stock is that you lose significant weight in the rear polar moment, where it really makes a difference.
SCWDP911 05-26-2007 06:12 PM
At the risk of being slammed, anyone have any reasons not to run a glass pack or something like it. My thought is to put it ( a short one like a Thrush) in place of the premuff/cat and muffler. On the outlet side, run a pipe over and to the middle of valance with the dual outlet pipes. Should weigh a LOT less than the two stock items combined. It seems I saw someone post a vid clip here with a somewhat similar arrangement. Just kicking the idea around for now...
dweymer 05-26-2007 09:01 PM
I had them on my 2.7, I liked the sound, but they were loud. It was just stuff I had laying around so I tried it.
mb911 05-27-2007 03:36 AM
The triad is bascially a series of glass packs so that is done all the time.
as to the flowmaster being lighter than stock I would kindly disagree. they are really heavy.
Remember this before I started my business I used flowmasters but they were just to loud, to hot(they radiat allot of heat) and to heavy.. thus my soulution. I do however love the sound so I tried to make our muffler sound as close as possible but toned down. which I think I pulled off pretty well.
If you want sound try stock with a second tail pipe. going to an aftermarket muffler is just to expensive.
V8 ranch if you would have put in a hi flow cat to your previous setup you would have been happiest the by pass makes them real loud good luck guys
89911 05-27-2007 05:04 AM
Use the Magnaflows. Lighter and sound great. No issues after 2 years.
Oh Haha 05-27-2007 05:10 AM
Look at Flo-Pro mufflers. I have one for a late model Camaro, single in/dual out with one side capped. It sounds great and really isn't that loud unless you are getting into it. I can carry on a conversation at speed without any problem. Cheaper than FM, too!
Oh Haha 05-27-2007 05:28 AM
http://forums.pelicanparts.com/uploa...1180272121.jpg On the car.
SCWDP911 05-27-2007 06:09 AM
Ben, do you mean the high flow cat with the stock muffler?
Oh Haha 05-27-2007 07:08 AM
EDIT: I trid uploading a couple of videos of my car to YouTUbe but had no luck.(First time trying.)
I can send them if somebody wants to host.SmileWavy
SCWDP911 05-27-2007 07:13 AM
Would you send them to me, I cannot host, but would really like to hear it.
vanweys@charter.net
rennch 05-27-2007 07:51 AM
@ 89911: Which magnaflow are you using?
@ oh Haha: Do you have any pics of the install? (Underneath) And which flo-pro are YOU using.
I guess the only reason I was using the Flowmaster is that it was a known commodity. And, since it's primary an autocross/race car, I wasn't SUPER concerned with the noise. If I had my druthers I'd run straight headers. :)
Oh Haha 05-27-2007 09:52 AM
Sorry, no good pics from underneath but if you duplicate Jack Olsen's setup that will work. Mine is a single in, BTW. Simple pipe from the premuff to the inlet and then one pipe for the outlet coming into the stock location. The other outlet is capped. I tried using it as a dual out and found the resonance to be too much. I don;t recall the part number of the muffler but they do carry generic sizes for dual inlet systems.
I had the muffler guy weld a tab on the backside of it so I could use the stock hanger. I had to connect two HD hose clamps together to simulate the muffler straps as the stock one wouldn't work. I bought the Flo-Pro because it was cheaper by almost half of the Flowmaster. Now, I see a lot of the street rods and pro street guys around here are using them.
