Header wrapping
Has anyone wrapped their headers?
Any problems?
Any benifits?
Any pitfalls?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 05-27-2007, 12:59 PM
RETIRED
Joe Bob's Avatar
Promotes rust......ceramic coat them if you really need to....
2012 ML350 3.0 Turbo Diesel
Old 05-27-2007, 01:14 PM
Now in 993 land ...
aigel's Avatar
It's a real PITA to do a good job. I have wrapped V8 american headers before. Definitely helped a lot with heat though and was a lot cheaper than ceramicoat.
George
81 SC (sold)
Old 05-27-2007, 03:28 PM
It keeps the heat where it supposed to go. No rust, unless you let them stay wet; but normally all moisture evaporates real quick after reaching oper temperatures. I use it w/o problems at all...
Old 05-27-2007, 04:05 PM
shbop's Avatar
Done several.
1.) Any problems? PITA to install well.
2.) Any benefits? You won't get burned as badly, if you touch them by acident. Helps reduce ambient heat.
3.) Any pitfalls? see #1
Jon
Old 05-27-2007, 04:46 PM
PITA
IT WAS A PITA!
But what do you think.....
Old 05-27-2007, 05:16 PM
RETIRED
Joe Bob's Avatar
Nice job.....just don't get them wet. I did and they rusted pinholes inside of three months.
Old 05-27-2007, 05:24 PM
Maltese Falcon's Avatar
Doherty, the old type fiberglass based header wrap was proll'y the worst, and the newer type materials are better. But like MikeZ sez, "Any trapping of moisture" and you're on your way to buying another pair of headers...btdt.
Just about all header mfg's (myself and even Bursch) will not warrant any damage claims when returned with evidence of heat wrap.
Marty
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 05-27-2007, 05:41 PM
I normally dont drive in the rain, but I will watch the water.
I am going to run the headers as a test to see if I like them, If I dont I will go back to an SSI setup. I dont like heat and dont like the fact that the heat from the heaters dumps into the engine bay, Some one needs to come up with a mod that takes care of that.
I have an idea, but I dont know how practical it is.
Old 05-27-2007, 06:11 PM
Installed
I got the headers installed, and they sound weird.....Just me I guess, Im not used to them. But when i got it home from my friends house where we put them on, i let it set for a minute just so I could listen and then took a look underneath and this is what I saw.....AT IDLE........is this normal?
And no that is not an orange light or paint, They were glowing orange at idle...
Maybe the stock ones did the same and we just never saw it because they are enclosed in a housing..
Old 06-01-2007, 08:20 PM
I've measured surface temps. of 400ºF + when the engine was idling. I suspect that with the wrap, the pipes are getting a little warmer under load.
Sherwood
Old 06-01-2007, 10:22 PM
Now in 993 land ...
aigel's Avatar
No surprise. Breaking in cams on V8 cars with headers, I frequently would see headers glowing red hot at 2000 rpm (no load). It would not get to that temp just idling, but if you drove it before, its nicely preheated.
George
81 SC (sold)
Old 06-01-2007, 10:25 PM
DUK DUK is offline
DUK's Avatar
Check your timing also. If your retarded too far it will also make them glow. But I suspect it's normal.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-02-2007, 02:44 AM
The timing was just checked, but I have been trying to get the CIS system set right and I believe it is on the rich side a little too much because I just fixed all the air leaks.
Old 06-02-2007, 06:22 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
You want to see something better?
Try looking at the tops of the pipes on an old Triumph or BSA 650 twin when running at night.
The pipes get so hot they turn transparent.
You can see the exhaust gases moving inside the pipes!!
Bob
Bob Hutson
Old 06-02-2007, 07:39 AM
