the911Tprocess's Avatar
short shift kit issue
I have a 72 911 T, I recently purchased a used shifter from a 73. It has the short shift kit installed (non factory). Fits great, feels great but I have a h** of a time hitting third.
I can hit fifth and reverse without any issues but hitting third and forth is difficult. What do I need to do to rectify this, I guess I will have to adjust the linkage. Any suggestions or knowledge that I can tap.
Thanks in advance,
_____________________
Mark
911 T 1972 Black almost done!
Old 05-24-2007, 05:43 PM
any ideas
anyone any ideas
Mark
Old 05-24-2007, 08:37 PM
I'm a loser, baby.
oregonmon's Avatar
Not that I've done either of these, but people talk about changing the bushings and adjusting the clutch cable maybe.
1979 911 SC
Old 05-24-2007, 10:40 PM
Now in 993 land ...
aigel's Avatar
Which aftermarket kit is it? If it is the weltmeister kit, you should throw it out and replace it with the factory short shift kit. My car came with the weltmeister kit and it was a POS. Way too short, so the planes 1-2 were dangerously close to 3-4. I was afraid I'd money shift it eventually and installed the factory short shift with all new bushings in the linkage and coupler.
George
81 SC (sold)
Old 05-24-2007, 10:50 PM
short shift kit
Thanks, I was afraid of that.
Mark
Old 05-25-2007, 06:33 AM
Now in 993 land ...
aigel's Avatar
It really isn't a big job and you don't even have to jack up the car or lay on your back either. I think the factory short shifter now is available again, if I remember right. When I bought mine, it was NLA and the parts places started charging extra for the few they could still find. If they are NLA, you may find one in the classified section if you place a wanted ad.
Good Luck!
George
81 SC (sold)
Old 05-25-2007, 08:37 AM
Now in 993 land ...
aigel's Avatar
Here a few pictures for ID:
The weltmeister kit in package (Sherwood (911pcars) posted this in an earlier thread) What about a Short Shift Kit?
And the kit installed. The tell tale sign on the weltmeister is the big spacer under the housing (from Help Identifying Shifter in 915):
Here is what you are after. The entire factory kit. Bill V. posted this in the first thread referenced.
Have fun!
George
81 SC (sold)
Old 05-25-2007, 08:50 AM
got it
Got the kit as discussed. Will install when I receive it and report back.
thanks for the advice.
Mark
Old 05-26-2007, 08:27 PM
Fahren mit dem Wind.
mhackney's Avatar
So, the factory kit is listed for years 72-86. What options are there for those of us with, say, a 1970 911S?
thanks!
Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 05-30-2007, 06:14 PM
jasam's Avatar
I went for the WEVO coupler and the WM SSK and it's amazing, I don't hace ANY problems with it, I changed the bushings and installed the coupler at the same time... It is wonderful... Like John Cramer said I wouldn't trade it for any aftermarket shifter...
There is no substitute
Old 05-30-2007, 06:24 PM
thanks!
Michael
Install a 73-86 915 shift housing and remove its reverse lockout pawl. Same bolt pattern to mount onto the tunnel. Shift pattern and detents are inherent in the gearbox, thus the shift lever merely transfers the proper shift motion into the gearbox.
This is our kit installed on a modified 915 shift housing. There are other manufacturers that provide similar shift features.
Sherwood
www.seinesystems
and available from our host
Old 05-30-2007, 11:27 PM
