rfuerst911sc's Avatar
Question 3.2 distributor question if going carbs
If you remove the EFI induction and ECU is there a way to use the stock distributor on a 3.2? If not what distributor can you use?
Old 06-02-2007, 11:16 AM
Navin Johnson
TimT's Avatar
I have a NA 3.2 in my 914.
The distributor is a recurved SC distributor. The stock distributor doesn't have an advance mechanism built in
'69 911 GT-5
'75 914 GT-3
and others
Old 06-02-2007, 01:01 PM
That must be a modified dist. as the SC's run counter clockwise right? Who did the mod?
Old 06-02-2007, 01:30 PM
Navin Johnson
TimT's Avatar
Yes its not a "stock" SC distributor. The name of the place that did the re-curve escapes me now..
Also the SC distributor went into my 3.2 whose case has never been split
'69 911 GT-5
'75 914 GT-3
and others
Old 06-02-2007, 02:24 PM
randywebb's Avatar
Steve W. can do that. Dunno who on E. Coast or SE.
Maybe Pdoc? - tho he's in TN.
You can always ship it for not much $$
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-02-2007, 03:17 PM
shbop's Avatar
Just went through this on a 3.0, and ended-up going with Electromotive/Clewett. A bit more up-front money, but great versatility and very simple install.
Jon
Old 06-02-2007, 03:42 PM
