If you remove the EFI induction and ECU is there a way to use the stock distributor on a 3.2? If not what distributor can you use?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Navin Johnson
I have a NA 3.2 in my 914.
The distributor is a recurved SC distributor. The stock distributor doesn't have an advance mechanism built in
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
That must be a modified dist. as the SC's run counter clockwise right? Who did the mod?
Navin Johnson
Yes its not a "stock" SC distributor. The name of the place that did the re-curve escapes me now..
Also the SC distributor went into my 3.2 whose case has never been split
Steve W. can do that. Dunno who on E. Coast or SE.
Maybe Pdoc? - tho he's in TN. You can always ship it for not much $$
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Just went through this on a 3.0, and ended-up going with Electromotive/Clewett. A bit more up-front money, but great versatility and very simple install.
Jon |
