126coupe's Avatar
MSD Question
My twin plug uses 2 MSD boxes. I want to change the rev limiter chip. Do I need to change both?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 06-04-2007, 11:37 AM
You sure do, unless you desire a split RPM limiter setup.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-04-2007, 12:55 PM
126coupe's Avatar
Thanks I figured that.
The bummer is i have to buy 2 packages of chips at $29.95
from Summit Racing, they dont sell individuals.
Does anyone have a 8200 and 8400 chip. I only need one of each.
28' Pace Trailer
Old 06-04-2007, 01:01 PM
Gon fix it with me hammer
svandamme's Avatar
i think it would suck bigstyle
if it suddently goes from twin plug to single plug ignition at those high revs...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-04-2007, 01:12 PM
126coupe's Avatar
I ran this engine to 8000 for 50 hours when it was a single plug..no issues
28' Pace Trailer
Old 06-04-2007, 01:22 PM
svandamme's Avatar
ah , i assumed it was a high boost turbo or nutty compression that requires twinplug for health reasons
Stijn Vandamme
Old 06-04-2007, 01:31 PM
126coupe's Avatar
turbo no, high CR yes 10.5:1
28' Pace Trailer
Old 06-04-2007, 01:33 PM
svandamme's Avatar
i guess that it's on the edge for single plug at those revs
sounds like a fun engine
Stijn Vandamme
Old 06-04-2007, 01:39 PM
barney911rs's Avatar
Rather then the plugs, they make an adjustable module that you can attach. It makes it really easy to change the rev limit. Not sure if you could wire both MSD's to a single limiter or not. Maybe Steve knows if this would work. I got the 6000-8200 module on my car.
MSD RPM Limiter
They would be $55 each, but it would cover almost the same RPM range as 3 sets of plugs at $28 each. Just an idea.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 06-04-2007, 01:51 PM
randywebb's Avatar
They are not chips - just resistors with a little plastic around them. Here is what I did when diagnosing a high rpm stumble -- caused by a wrong value resistor they used.
You save a lot of $$ -- just use matched resistors - spec a high accuracy one if you want or hand match them.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-04-2007, 03:34 PM
