MSD Question
My twin plug uses 2 MSD boxes. I want to change the rev limiter chip. Do I need to change both?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
You sure do, unless you desire a split RPM limiter setup.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks I figured that.
The bummer is i have to buy 2 packages of chips at $29.95 from Summit Racing, they dont sell individuals. Does anyone have a 8200 and 8400 chip. I only need one of each.
Gon fix it with me hammer
i think it would suck bigstyle
if it suddently goes from twin plug to single plug ignition at those high revs...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
ah , i assumed it was a high boost turbo or nutty compression that requires twinplug for health reasons
i guess that it's on the edge for single plug at those revs
sounds like a fun engine
Rather then the plugs, they make an adjustable module that you can attach. It makes it really easy to change the rev limit. Not sure if you could wire both MSD's to a single limiter or not. Maybe Steve knows if this would work. I got the 6000-8200 module on my car.
MSD RPM Limiter They would be $55 each, but it would cover almost the same RPM range as 3 sets of plugs at $28 each. Just an idea.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
They are not chips - just resistors with a little plastic around them. Here is what I did when diagnosing a high rpm stumble -- caused by a wrong value resistor they used.
You save a lot of $$ -- just use matched resistors - spec a high accuracy one if you want or hand match them.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
