defcon65's Avatar
Didn't know, thanks for the heads up. Isn't there a peel and stick neoprene material used for the same effect? That's what I'm looking for. I saw it used to line an inboard boat engine compartment, and I've seen similar stuff in car audio installs. It's about 3/8" thick, very dense with adhesive on the back.
I don't mind the engine sound so much, but the adhesive residue looks like rust and I want to clean up the engine compartment.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 06-11-2007, 12:52 PM
randywebb's Avatar
They make something for underhood use - it might be ok on the motor side of the firewall. Likely heavier than the stock pad tho.
One thing is you sure can't beat that price.
I am wondering what makes him say the product is the best one made - do you know? Or is it just 'company pride?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-11-2007, 01:36 PM
"He says it's the best sound deadening material out there."
Could be, for audio purposes, but it's heavier than some alternate materials. There are other sources for basically the same material, but w/o the Dynamat trade name attached (makes it pricier).
Sherwood
Old 06-11-2007, 03:24 PM
Happiest when Tinkering
gsmith660's Avatar
I am doing a complete restore so I am going to put my sound mat on the other side of the sheet metal and leave this nice looking paint
Old 07-26-2007, 01:22 PM
That looks KILLER!
1981 911sc Targa - gone but not forgotten.
Old 07-26-2007, 05:10 PM
MBruns for President
JeremyD's Avatar
I have the bling bling Yo Boy foil backed - trimmed appbiz aftermarket sound pad - it's light - it deadens the sound on par with the factory pad, it doesn't fall apart, and I have seen no difference in engine temps even running a larger displacment, hotter cams and higher compression
Old 07-26-2007, 06:18 PM
911 in SC's Avatar
Jeremy, did you buy the sound pad with the perimeter binding or without? How's the heat inside the car? Any different?
Thanks,
Mike
Mike
'84 Grand Prix White RoW Carrera
Old 07-26-2007, 06:24 PM
JeremyD's Avatar
With binding - no difference in heat or sound
Old 07-26-2007, 07:18 PM
911 in SC's Avatar
Sorry for all of the questions BUT did you try it without either sound pad? I don't have a pad now, and the rear seats do get a little warm. I'd like to keep the temps down, as my 7 yr. old daughter doesn't complain, but I want to keep her as comfortable as possible. If the pad will reduce temps inside, it's well worth it. If not, I'll keep my car the way it is (it sounds great!).
Thanks,
Mike
Old 07-26-2007, 07:29 PM
AutoBahned
RWebb's Avatar
Once heat or noise 'hits' the sheet metal it is much harder to deal with. The sound pad on the engine side is going to be much more effective at both heat & noise control.
OTOH, that bare but finished texture does look good - so if you have carbs or something that let's you see the firewall, then you have to balance the visual w/ the heat/noise issues.
I prefer the Al foil type pads if you want that maximum "Roasted Chicken" bling effect.
Old 07-26-2007, 08:52 PM
I installed some Mylar-backed, 1" foam material out of the JCWhitney catalog; created a pattern with paper, tape and scissors, then transferred onto the material. Added Mylar tape to cover the cut edges. I believed I used contact cement on the bulkhead as well as the foam.
Since my car was out of commission for years when I did this, I can't speak for the sound or heat reduction of such a pad. As a wag, i'd say it reflects some heat and reduces some sound.
2-year old photo:
Sherwood
Old 07-26-2007, 09:08 PM
JeremyD's Avatar
Ha Ha - knew Randy would chime in - Do you think that's why I am getting all this HP? Maybe the foil backing is focusing the power waves from the flux capacitor...
Old 07-27-2007, 06:02 AM
JBO JBO is offline
I used the same stuff Sherwood used, but I got it at Pep Boys. I wasn't concerned about the sound, and was mainly concerned about a hotter passenger compartment with no pad. It has been in place a few years now and seems to work well.
Old 07-27-2007, 06:17 AM
gsmith660's Avatar
Im going on the same principle that you put dynamat on the inside fo your doors to stabilize the metal and on the outside of the inner door panel to cut vibration from the stereo resonance
Old 07-27-2007, 07:54 AM
AutoBahned
RWebb's Avatar
regular Dynamat works primarily by making the panel heavier
a heavier panel has a resonant frequency that is lower than a lighter panel; the peak amplitude ("Q") is also reduced
an analogy is sticking wad of asphalt on a kid's drum head - the metal panel is exactly like the drum head (since drummers tend to have strong forearms, this experiment is best carried out using a young kid)
Old 07-27-2007, 08:12 AM
gsmith660's Avatar
I always thought that it was kind of like the the radar absorbant material on planes it would slow down the wave as ait traveled thru the material until the amplitude dropped off to 0
Old 07-27-2007, 10:42 AM
Just to add another theory;
I thought the added material changes the vibration frequency of the base material.
Quick. Someone call JCWhitney tech support for the answer.
Sherwood
Old 07-27-2007, 11:36 AM
AutoBahned
RWebb's Avatar
"changes the vibration frequency of the base material."
- isn't that what I said??
Old 07-27-2007, 02:21 PM
Randy,
Yeah, but I wanted to say it too.
Sherwood
Old 07-27-2007, 02:38 PM
gtc gtc is offline
abides.
gtc's Avatar
After reading this thread this morning I went out at lunch and pulled out my old, falling off and apart factory pad, then went for a drive. There wasn't any appreciable difference in sound levels.
Graham
1984 Carrera Targa
Old 07-27-2007, 02:57 PM
