Engine sound pad question... which one to use?
I purchased an Engine Compartment Sound Mat from our host: 911-556-891-01-M260, Latest OEM version (lighter-weight material),
My question is: The pad seems awful light and airy. Can anyone tell me if this pad offers as much sound deadening as the older heaver version of the pad?
The old pad number is 911-556-891-01-M136.
Thanks,
Arron
1981 911sc Targa - gone but not forgotten.
Old 06-08-2007, 11:21 AM
911 addict
mtbguy's Avatar
I just bought the shiny (non-OEM) one from Pelican. My shop says it works well, although I was wondering also the same question.
Has anyone ever compared the sound levels?
Buehler?
1987 Carrera Cab
Toyota Landcruiser
500SL
Old 06-08-2007, 11:24 AM
19 years and 17k posts...
azasadny's Avatar
I bought the original, heavy sound pad a few years ago and it's already failing. Next time i will buy the new, lightweight version...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-08-2007, 12:18 PM
Scott R's Avatar
I dropped my engine the first time about a year ago, I changed from the aging heavy sound pad to the new OEM version, I never noticed a change in the noise level.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-08-2007, 12:27 PM
MHO. For effective sound attenuation, material should be applied to the surface, not just glued onto it. I vote for a material that sprays or brushes onto the bulkhead which is basically a flat, wide sounding board. Blanket-type materials may help slightly, but it's more effective reflecting heat (if shiny).
Sherwood
Old 06-08-2007, 01:59 PM
randywebb's Avatar
Spray glue will do just fine - I do that and then use tube stuff around the edges and in big X's on the panels.
- use the 3M stuff BTW - There are 2 types, I forget which to use.
I favor the new, lightweight, factory pad.
Also, a small air gap between the pad and the firewall could help or hinder sound isolation - it depends on the frequency, and is, as they say, non-trivial.
Foams will generally do a better job of inhibiting sound and heat transmission (the dual jobs of the pad) than will a fibrous material. I have no idea what the shiny after-market pads are made of - could be foam under the metal foil.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-08-2007, 03:42 PM
Used Up User
imcarthur's Avatar
I ran without a sound mat for a couple of months & then installed the new OEM one from our host. Installed as Randy suggests. The difference - none vs new OEM - was significant. Much quieter imho.
Ian
'87 Carrera Cab
Old 06-08-2007, 04:30 PM
Well then I guess I will install the pad this coming week. I plan on using the weather strip glue for the install. IˇÇm not a fan of the spray on gules as I have never had any luck with then holding over long periods of time.
Old 06-08-2007, 06:58 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I used no adhesive at all, and have had no issues. It will press-fit into place using the stock clips that are found along the upper edge of the firewall. You will save some aggravation doing it this way if you ever have to remove it again.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 06-08-2007, 07:01 PM
I noticed that there are two screw holes on the wall behind the engine. IˇÇm wondering if I can use the stock clips with two screws and washers to hold the mat in place.
Old 06-08-2007, 07:04 PM
UFLYICU
ZOA NOM's Avatar
Definitely. The mat will stay put. I'd forget the adhesive.
prc-racing.com
Old 06-08-2007, 07:14 PM
Evil Genius
Rusty Heap's Avatar
I just bought the silver foil backing with red piping perimeter trim.
Will shoot some pictures once I get it mounted and engine re-installed.
ANYTHING will be better than what the stock unit had deteriated to......rags of tar paper and fiberglass matting shards
Life is a big ocean to swim in.
Wag more, bark less.
Old 06-08-2007, 10:05 PM
PSJoyce's Avatar
I installed the four-layer “ultimate sound pad” yesterday. It does reduce noise, at least compared to the 22 year old crumbling and sagging original foam pad. Not about sure the acoustic effect of 5 or so pounds of shells, seeds and mouse poop that had accumulated in those sags. I did use 3M adhesive near the top end. The mat sagged between the metal clips on the firewall without it.
Paul
Before:
After:
1985 911 Carrera
Moss Green Metallic
Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning
Old 06-09-2007, 05:49 AM
Paul
Before:
After:
I take it you dropped the engine to install?
1987 Carrera 3.2
Old 06-09-2007, 06:21 AM
PSJoyce's Avatar
No, room to install the pad wasn't too bad at all. I did spend a lot of time with the shop vac.
Paul
1985 911 Carrera
Moss Green Metallic
Old 06-09-2007, 06:28 AM
PSJoyce's Avatar
I should add more details.
There were some tricks. Getting the old pad out was easy as the adhesive had completely failed. I did try to contain the mess as much as possible with an old blanket over the motor and engine compartment.
I did:
Remove the air cleaner and cover (new air filter)
Remove hood shock (new hood shock)
Unbolted the bracket for the cruise control canister on the left side. This was key -- there is no clearance at all between that canister and the bracket for the hood shock. It took a lot of hand and wrist flexibility to get a 10mm wrench in there, but wasn't too bad.
Then, just slid the new pad in dry, and guided into position. I pulled the top of the pad down, sprayed in 3M spray adhesive where I could, and put a line of 3M Weatherstrip Adhesive along the edges, and pushed it into place, re-bent the clips, and put the other parts back on.
All together, about 2 hours, and would be less the second time.
Paul
1985 911 Carrera
Moss Green Metallic
Old 06-09-2007, 07:38 AM
Slumlord
Porsche_monkey's Avatar
I just sprayed mine with rubberized rocker panel goop. It looks good, and I won't have a crappy looking sound pad a year from now.
Of course, I like the noise.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-09-2007, 08:26 AM
defcon65's Avatar
I'm going to do mine with Dynamat, eventually. A friend installs car stereos and has pieces I can have for free. He says it's the best sound deadening material out there.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 06-11-2007, 12:18 PM
randywebb's Avatar
you mean on the interior side, right?
Old 06-11-2007, 12:36 PM
Scott R's Avatar
not a good idea, when regular Dynamat gets hot it falls apart, quickly. They make a special underhood version now for this very reason. As a matter of fact I know a guy that put it on the bottom of a metal sink to cut down noise and the hot water made it come apart.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-11-2007, 12:40 PM
