Kevins911's Avatar
Can I use an MSD and a Crane XR700 together?
Like the title says I just installed a '77 2.7L engine in my car, but the dizzy has no points in it. I allready have an MSD 6AL and MSD coil installed, can I use my Crane XR700 with that?
Kevin
'73 914 2.0L
Old 06-21-2007, 05:15 PM
I would rather be driving
jpnovak's Avatar
You don't even need the XR700 package, just the optical trigger. Feed the white wire from the distributor into the MSD as a points input. Will work with no problem.
Old 06-21-2007, 06:48 PM
Kevins911's Avatar
perfect, I'll give that a try. Thank you.
'73 914 2.0L
Old 06-21-2007, 08:56 PM
Not wanting to clutter up my garage with more stuff, I left the XR-7 box in the car and installed a Crane Hi6S on top of everything. I know, not the KISS principle, but it ain't broke, so I ain't fixing it...... yet.
The connections to an MSD box should be similar.
Sherwood
Old 06-22-2007, 12:52 AM
jluetjen's Avatar
I've got that in my car. I posted a schematic a couple of years ago. If you do a search on my posts and "ignition" you'll most likely find it pretty quickly.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-22-2007, 10:42 AM
Here's my Hi6S with a XR-700. Solo XR700 since 1998. Combo still works fine after 3+ years. Crane Hi6S was mounted this way to access the rpm limiter controls on one end.
Sherwood
Old 06-22-2007, 04:39 PM
jluetjen's Avatar
Here's my schematic...
John
'69 911E
Old 06-23-2007, 06:17 AM
Kevins911's Avatar
Again, thanks for the replies, very helpfull info. But the engine is out of the car again, it seems to be locked up, it will turn almost a full rotation and stop and it will turn back and stop. Good enough reason for me to pull it apart and throw in my RS(or better) pistons and some S cams
Kevin
'73 914 2.0L
Old 06-23-2007, 07:41 PM
