Take a look at these sparkplugs please
Hi guys,
The car is a 73 911 with 2.4 mfi
I'm right in the middle of a service and i noticed this...
These are the plugs i was given at the shop, under inspection they are 2mm longer than the old ones.
Are these plugs going to bash a hole in the top of the piston or will they clear?
as always many thanks in advance
submit signature here
Old 06-12-2007, 05:00 AM
I'm no plug expert, but it looks to me like these are different heat ranges and I would not put them in until triple checking with various sources and turning the engine over by hand before starting.
Sold: 1989 3.2 coupe, 112k miles
Old 06-12-2007, 05:23 AM
cycling has-been
bkreigsr's Avatar
these are the plugs Porsche specifies for this application:
999 170 128 90
extended tip, old school, wire electrode.
resists the typical fouling, but they are $14.00 each from our host.
Bill K
Old 06-12-2007, 05:34 AM
Those plugs are just fine,...
The extended tip design helps keep them clean.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-12-2007, 08:04 AM
David's Avatar
The stock plugs are a projected type like the one on the right, the other's not. I've used both and not noticed any difference.
Old 06-12-2007, 11:07 AM
The only thing I don't like about the plug on the right is that it isn't NGK :-)
Old 06-12-2007, 12:50 PM
I know its better, its a Bosch. Bosch plugs also don't blow through the ceramic like NGK and Champions do.
Old 06-12-2007, 02:48 PM
ok, we will see.. I just installed NGK on me 3.2.. runs fine so far keeping my fingers crossed I guess
Old 06-12-2007, 02:53 PM
