wcc wcc is offline
wcc's Avatar
R12 to R134 Conversion Question
To convert R12 to R134 is it as easy as changing the fittings on the compressor?
Bill
997.2
Old 06-12-2007, 05:44 PM
Semper drive!
rcecale's Avatar
It's probably best if you have a shop do it for you. You have to evacuate all of the R12 out of the system before you can install the R134. They can't co-exist in the same system.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-12-2007, 05:54 PM
wcc wcc is offline
wcc's Avatar
I've had the system evacuated already and I replaced the expansion valve and the belt. So now it's ready to be charged. I'm just wondering if I can just change the fittings and use the R134 instead of the R12. If it leaks out really quick then I'll look into those barrier hoses.
Bill
997.2
Old 06-12-2007, 06:04 PM
the the is offline
I was at a local car parts place the other day, and saw a $49 R134 kit.
Basically, the instructions said (1) evacuate system, (2) change the fittings, (3) put in the 134.
That seemed a lot easier than I had thought.
Old 06-12-2007, 06:13 PM
shbop's Avatar
Don't forget the oil>
Jon
Old 06-12-2007, 06:17 PM
wcc wcc is offline
wcc's Avatar
That's why I'm asking cause it seems too easy. But that would be a nice to have an easy project for a change....
Bill
997.2
Old 06-12-2007, 06:19 PM
Semper drive!
rcecale's Avatar
You can't just add more oil to the system. R12 oil is different that oil for R134 and they cannot be mixed.
Basically, getting rid of the "hazmat" is the tricky part of the job. Once you've got that done, you're home free. Just make sure yu put the new valves in the proper locations.
Randy
One Marine's View
Old 06-12-2007, 06:40 PM
MBAtarga's Avatar
You also want/need to change out the drier.
Mark
'83 SC Targa - since 5/5/2001
Old 06-12-2007, 07:08 PM
johnman001's Avatar
I think what I read is that the rubber lines really should be changed as well as they will leak R134a. Barrier hose is recommended.
The compressor (unless thoroughly cleaned) will probably fail shortly after introducing the R134a. The oils and seals used just are not 100% compatible. Get a rebuilt or new compressor.
Like Mark said, you will need to change the drier as well.
I investigated this and actually have the parts to do mine, but have not yet gotten around to doing the change-over.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 06-12-2007, 08:48 PM
Don Plumley's Avatar
I've done a little research on this for my kid's car.
There's a perfect way, a reasonable way, and a bad way.
The kit in the autoparts store is the bad way. They use an oil that's missable in both R12 and R134. But it would only work to salvage a system that's too costly to repair - and cooling would be lukewarm at best on a mediocre system.
The perfect way is to replace the compressor, receiver/dryer, flush the condenser, replace the oil, deep vacuum, then charge with R134.
The reasonable way is to replace the R/D, blow out the oil in the condenser, replace with PAG oil, deep vacuum, then charge with R134.
The problem is that R12 does not need as much compression as R134, so it wears the compressor faster and does not provide as efficient cooling. In the big picture, you are probably better off staying with R12.
Don Plumley
M235i
Old 06-12-2007, 09:19 PM
I once had a shop that did a long distance PPI for me, convert a car I was buying from R12 to R134, without my knowledge. Naturally, he did it without changing all the important parts and the system was essentially useless afterwards. These systems are marginal on R12. On R134, they are utter crap, unless you re-engineer them.
Stay with R12.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 06-13-2007, 04:19 AM
wcc wcc is offline
wcc's Avatar
There are a couple of places in town that still do the R12. I'm going to take it in on Friday and have it charged up. It's about $50/lb and about $30 for labor if anyone is wondering what R12 is going for.
Bill
997.2
Old 06-13-2007, 04:31 AM
MAGA
Tim Hancock's Avatar
Bill, I charged mine with 134 a couple years ago and am quite pleased with it still. DIY 134 conversion in SC complete!
Let me know if you want to chat about it, I can PM you my cell number.
After two years, I just had to add one cheap can of 134. Pretty good considering it still has stock hoses and an old York compressor.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 06-13-2007, 05:24 AM
Oh Haha's Avatar
Bill,
There is another option:
Rip all of the hardware out and lighten the car up!!
j/k I know Sandy likes the air.
We'll see how much MY wife will put up with this weekend on the drive with the new seats and no air. Oh, it's supposed to be 91 degrees that day. Woohoo!!!!
Pacific Blue
Wayne
Old 06-13-2007, 05:48 AM
DB_NC_95C2's Avatar
Whole hog is the best bang-for-the-buck.
I needed to keep A/C in my SC for this climate. I had read enough about old hoses leaking R134A so chose barrier hoses, my compressor needed either a rebuild or replacement so new rotary seemed an obvious choice, and in addition chose a new evaporator and 'procooler' (receiver/dryer) from Rennaire. I'm extremely happy, it was just another one of the many 'upgrade when time to replace' choices I've made. On all but the most unbearable of days (around here that means mid-to-high 90s and soupy humidity) it's quite comfortable in the car. No, due to the limited vent space it isn't like a modern car, but very liveable. So I would recommend if you're doing A/C stuff, use the same mantra as that applied to someone shopping a 911, i.e. "choose the most that you can afford"
'95 Porsche 993 Carrera, DACH-X, DACH-R, PSS10,RS Speedlines,RS StrutBrace, GT3TEK 993RS Aero
'06 Mini Cooper (O.Z,MTH, Milltek, M7)
http://www.hakkinen.com/spain99-mh1st-easy.mp3
Old 06-13-2007, 09:38 AM
jeff1hughes's Avatar
I believe that it is ester oil that is compatible with both systems. Most of the do it yourself kits come with a "charge"(presurized) can of this type of oil that you can put in. Before doing this I really recomend flushing your system out. You can get something like Dura 54 (NAPA) to poor into the disconnected lines, then use shop air to shoot it out the other end (disconnected too!). I've also heard that you can just use brake cleaner too. Do this with all lines, through the condensors and evaporator (not the pump or the drier). Oh, and when you do this, make sure you put on a new drier - it just has to be done, they're only like $35-$40. And by the way, R134 really doesn't just leak out the hoses in a year. Systems that leak that quick have a bigger leak somewhere else!
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 06-13-2007, 08:11 PM
rnln's Avatar
wcc,
becareful, someone told me they have/use R12 but when the car is in the shop, they used Freeze 12. If you argue, they said this is R12 compatible. It lasted me several weeks.
The second time I did (actually the shop did), with a lot of research and questions on this board. Evaculate all R12, test leak, replace dryer, conversion kit (adapters), then pump 134. It lasted me several weeks now and still cold. I am crossing my fingers.
Fat butt 911, 1987
Old 06-13-2007, 09:11 PM
wcc wcc is offline
wcc's Avatar
Update: I changed the drier today and had the system evacuated. It held a vaccum and then they charged the system with R12. It took 3lbs. I gotta say WOW it sucks bad! Around town you might as well forget it and on the E-way with the RPMs around 3k it blows cool on high. Anything less then high it's cooler then outside air but not enough to make a difference. This project was a waste of time and money.
Thanks a lot for talking with me about it over the phone Tim. I really appreciate it.
Bill
997.2
Old 06-14-2007, 05:04 PM
Semper drive!
rcecale's Avatar
That does suck!!! and it's also the same experience I've had for the past few years.
This year, I decided to try something new...my mechanic charged me $300 for the whole conversion and R134 charge. I now have a system that works WAY better than it has with R12.
On the drive to work in the morning, it's usually low - mid 70s outside. I can barely run the thing, it gets that cold in the car.
During the day lately, it's been high 80s, low - mid 90s... My car parks in the sun all day, so it takes a few minutes, but it really gets nice and comfortable inside.
It just might be worth the investment to convert.
Randy
One Marine's View
Old 06-14-2007, 08:41 PM
billroth's Avatar
Randy,
What exactly did your conversion entail? Evac, flush, dryer and charge? Or was there more to it?
Lawrence
1985 911 Coupe Black
1985 911 Cab GP White (killed)
Old 06-15-2007, 12:23 PM
