si Banker's Avatar
Accu-sump
Has anyone installed one of these systems on their 1984 to 1989 911? It is an addition to your lubrication system and consists of a small oil tank, one to four quarts, which is pressurized to reduce engine excessive engine wear during start up.
Any feed back would be appreciated or opinions
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 06-15-2007, 02:52 PM
Gon fix it with me hammer
svandamme's Avatar
i think more use would be found from preheating the engine oil
pressure isn't to much of a problem on startup with a 911
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-15-2007, 03:05 PM
DanielDudley's Avatar
You have a dry sump and a big oil tank that would make the accusump redundant. They work well on 944s and 928s, but are really only needed when running track tires, as normal cornering Gs are not sufficient to cause starvation.
To answer your more specific question, the bearings on a 3.2 are about the last thing that goes on the engine. Waiting until the engine warms up before using more than half throttle will add more life to your engine than anything else. This is IMO a cause of premature valve guide wear, but I am not a doctor or a Porsche mechanic, so I am prepared to stand corrected. I think that switching to Redline or a similar oil would be more to the point. LOL
Old 06-15-2007, 03:16 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The accusump is for pre-lubing the engine before starting.
You charge the reservoir before shutting down...and then release it into the galleries before hitting the start button.
The idea is to prevent dry starts.
It has varying benefits....some good...some redundant.
If you have the right oil in the engine...the bearings are still wet and by the time the crank has turned a couple of times...the pressure is already up.
Bob
Bob Hutson
Old 06-15-2007, 06:15 PM
RETIRED
Joe Bob's Avatar
Good for engines that don't have a dry sump.....
2012 ML350 3.0 Turbo Diesel
Old 06-15-2007, 06:20 PM
Super Moderator
cstreit's Avatar
Well they also have some applicability to the 911 guys. In particular they are very popular with racecars to even out low pressure situations. As many of you know the 911, particularly the SC and earlier cars had oil-starvation issues during heavy braking and heavy left-hand turns because of the pickup location in the tank.
The Accusump will add pressure to the system if it drops too low, saving critical bearings and giving a little longer time for shutdown int ehevent of pressure loss for some other failure.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-15-2007, 09:00 PM
randywebb's Avatar
the motors will go 200k to 300k or more miles without these things... so...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-15-2007, 10:52 PM
Diss Member
Quicksilver's Avatar
There might be something in there though. In the early 70s my dad saw a number of big block Chevy crewcabs that were getting over 200K miles without a rebuild because the engines were never shut off. (building the Alaska pipeline) At that time the normal life expectancy of a big block cam was about 80K miles.
Not sure how much of the improvement was from avoiding the momentary lack of oil on startup and how much was from the fact that the motor was always warm.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-16-2007, 05:54 AM
svandamme's Avatar
my money is on the always warm part
oil pressure isn't a problem on a cold engine, it builds up fast, and during warm up the oil pressure will be higher then when the engine is hot... the oil however will be colder
manufacturers design their engines to warm up as fast as possible, hence the use of thermostat's to eliminate cooling during that stage of engine operation... and another reason why one should never warm up the engine by idling, because it takes longer...
so preheating the oil, is way more of use then pre-pressurising the system... it's a rather common practice for airplanes to preheat the oil tanks ...
Stijn Vandamme
Old 06-16-2007, 06:01 AM
Super Moderator
cstreit's Avatar
I've installed two, but no pictures, and in both cases the accusump was installed in the cabin of the racecar because they were manual valves. The lines were plumbed into the pressure switch on top.
I suppose if you were creative you could install them into a T-fitting on any oil-line, though ideally you'd want it at the exit of the oil-pump pressure side... ...requiring tapping the case.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-16-2007, 09:57 AM
Registered Loser
I read a post on here a few yeas ago from a respected member saying emphatically that an enormous amount of engine wear occurs at startup. I confess I don't recall the member's name or the thread. But in any event, if that post was accurate, then accusump might be a good choice even for dry sump motors. After all, rebuilds on 911's are outrageously expensive. Why go 200k if you can go 600k?
Owner of a wrecked 944
Old 06-16-2007, 01:20 PM
svandamme's Avatar
the stress at cold start, is because none of the parts are designed for cold running, all the specs are designed to be optimal after they had thermal expansion... hence the requirement to get it warmed up asap..
i fail to see what this accusump would do, my 911 had max pressure in a flash after starting, not even delay on the gauge, it's just there right away, cause the oil is thick
Stijn Vandamme
Old 06-16-2007, 01:25 PM
Let's look at the value of an Accusump from another angle...and let me ask a follow-up question.
Our supposedly "superior" dry-sump oiling systems are not all they're cracked up to be. The "S" hose from the engine to the bottom of the tank connects to the tank at the wrong end....heavy braking during a DE event will uncover the rear pickup point and you might as well have a wet-sump engine. It shoulda been placed in the front. There is more chance of a 1g braking action than a 1g acceleration ( !) action.
Some people baffle the tank ( do a search) and some add more volume to the bottom-end of the tank to help keep the pickup covered in oil.
Is there a way to plumb-in an Accusump to help with this problem?
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-17-2007, 11:31 AM
si Banker's Avatar
Accu Sump
My understanding of the system and value it brought to the table was how it reduced the wear that is incurred during start up. I also thought that this might be even more important in the case of cars that sit for long periods of time between starts. An additional benefit was that IT added an additional 2 to 4 quarts of oil.
Even if the benefits of reduced engine wear during start up were very small, anything that helped reduce the need for a rebuild would be worth doing. I have paid for three rebuilds over the past 25 years and they are nIT getting any cheaper.
On a separate nITe, has anyone increased the capacity of their oil tank? If so by how much. 911 engines are as much oil cooled as they are air cooled. I have always thought that one of the benefits of a dry sump system is that there is the ability to carry a larger supply of oil.
1987 911 Coupe
Old 06-18-2007, 07:25 AM
svandamme's Avatar
to much oil would cause problems with warm up again
an engine should warm up as fast as possible
more oil = slower warmup, and a running condition which is less then optimal and yields more wear
in winter time, some drive with less oil , because the engine hardly warms up as it should on a full 9/10 quarts
again, you'de have more benefit from an oil preheater, then from the accusump when it comes to preventing startup/warmup wear
Stijn Vandamme
Old 06-18-2007, 07:33 AM
si Banker's Avatar
Accu Sump
The oil temp can and is controlled by the thermostat which is part of the system. In the winter, here in Texas, when the temp is at 40 degrees the thermostat does not open on a short trip. You can check by feeling the oil lines in the front fender well. Granted, if the oil tank is larger it will take longer to reach the temp to open the thermostat.
In the winter I have had to block off the air flow one of the oil coolers in the front of the car. I have added a second cooler in the left front fender well in place of the washer bottle. In the summer at 100 degrees plus it's a different story. The additional cooler and oil lines have increased the oil capacity to 12 quarts at oil changes.
1987 911 Coupe
Old 06-18-2007, 07:50 AM
gestalt1's Avatar
here is what i'm doing. i installed a 3qt accusump in the front abve the oil cooler duct. i'm running an-8 socketless hose through the interior to the port in the top of the case where the warning light sensor goes. i found a 10mm x 8an adaptor on summit racing's web site. i decided to add the accusump for the oil starvation due to g-forces reason, i agree the start-up wear is not a big deal on our engines.
Old 06-18-2007, 08:10 AM
si Banker's Avatar
Accu Sump
Does the system, Accu-Sump, stay under pressure until there is a "need" for additional oil? If it is needed does it re-set it's self?
1987 911 Coupe
Old 06-18-2007, 08:18 AM
svandamme's Avatar
quick questions,
how often does did the starvation occur,
how hard were you cornering when it did occur
do you think it would occur if you didn't have the fancy oil cooler setup you have now, with the longer oil return track to and from that front oil cooler and i presume a probably big front cooler
Stijn Vandamme
Old 06-18-2007, 08:19 AM
si Banker's Avatar
Accu Sump
There is nothing "fancy" about the system other than an addition oil cooler which is about the size of the cooler in the right fender well. The challenge I face is not getting the car to perform on the track but to survive on the street and deal with the excessive heat we have here in Texas. I do not like to see the oil temp get over 200 degrees and never over 220 degrees. The problem I had before adding the additional cooler was when the car got really hot ,as when you are caught it traffic for a couple hours with the ac on, it took for ever to cool down once the traffic began to move.
I just returned from New Mexico and running at 90-95 mph with the ac on my oil temp was 180-190 degrees. The pressure was always higher than the rpm of the motor, ie 3000 rpm with 4 bars pressure.
My interest in Acccu-Sump is that it might mitigate any "start up wear". I plan on keeping the car for a long time.
1987 911 Coupe
Old 06-18-2007, 08:38 AM
