Hey guys, so yesterday, I was getting my car ready for a track event today, and decided to change my tranny oil with mt-90.
Upon removing the drain plub, I found 8-9 needle bearings on the drain plug magnet. Then I remembered that I had recently started hearing a strange grinding/whining sound in any gear at low rpm/high load. The noise would clear out after 2800rpm. Sounded like a ring and pinion noise. Anyway, I am hoping that these needle bearings are from the diff area, which would not require an engine/tranny drop, but I do not know g50 trannies well enough to know where these bearing bits could have come from. Anyone know? Thanks!!
Mike 03 996tt w/efr7163 89 Carerra 3.6 |
Schleprock
Those look like needle bearings from any one of the gearshaft needle cage bearings upon which the gearsets ride. That's not a good sign and you should open up the transmission to see which bearing cage has disposed of those needles!
Kevin L '86 Carrera "Larry" |
Wow! Bummer. That can't be good. Good luck.
Thanks guys, so definately need to drop the tranny and open it up. AHHHH! I have no time for this, so I won't be enjoying my car this summer
The diff's spider gears run on those needles. They are separated by a spacer that gets pinched and then cracks. When the needles spill out, they are free to migrate around the transmission (and a few may get ground up in the meshing R&P). There are a couple cures for this... I'll try to scan something today.
Geary, thanks, you gave me some hope! I patiently await the scan!
UFLYICU
There's a clue in your sig. These cars aren't made for drag strips.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
With a few mods, the G50 is successfully used for drag racing (although the earlier 915's definitely won't survive for long ... )
UFLYICU
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 06-18-2007 at 09:53 AM.. |
UFLYICU
In the past, Porsches have definitely NOT belonged on the strip. But with the G50 trans, spool (or LSD), and 1st-4th dog box conversion, Porsches are whipping a** in the quarter mile.
Mike, I'm having file size problems in storing my "fix" page on a friendly server. However, I'd be more than happy to mail the page to you, if you (or anyone else) PM me directly at:
gtgears@yahoo.com |
UFLYICU
Well, your tits are showing ...
http://www.thesamba.com/vw/forum/album_page.php?pic_id=296774 |
Ooooo. That cannot be goood..........
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
UFLYICU
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 06-18-2007 at 09:32 PM.. |
Large Registered Member
I'll take bouncing boobs over a mullet any day of the week!
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Mike's needles weren't the result of drag racing.
The car in the photo was an early parts tester. The G50 dog box conversion (that happens to do well in drag cars) is the DIRECT predecessor to the GT3RSR and Cup sequential transmissions used by Porsche today. http://www.thesamba.com/vw/forum/album_page.php?pic_id=360388 |
