911Blast's Avatar
How do you remove the rubber on flag mirrors?
I am painting my 79 SC and have removed the stock flag mirrors.
Does anyone know how to remove the rubber surrounding the glass without breaking it? I think Rubic's cube was easier.
Any advice would be greatly appreciated!
Thanks!
JB - 911Blast
Noah can kiss my ass !!!!
Old 06-18-2007, 05:20 PM
I'm sorry I don't have an answer to your question but I'll be removing mine to install 993 mirrors once I get them back from the body shop. Can you tell me how you removed your stock mirrors? Thanks
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-18-2007, 07:33 PM
step 1: use a plastic putty knife to remove the mirror glass. Be careful because there might be a heating element behind it that can break along with the mirror itself.
step 2: use a nut drive to remove the power window mechanism. this may not be the case on a '79.
step 3: unscrew 3 or 4 Phillips screws to remove the mirror body from the arm. If it's power you will need to unplug a wiring harness as well.
step 4: Removing a small round plastic cover between the mirror arm and door body reveals an hex key that must be loosened (not removed... watch out parts fall into the door!) to remove the flag mirror arm from the door.
Step 5: cut the old seal to remove.
Step 6: slide the new seal over the arm and reassemble. you may need to cut a portion of the seal interior to accomplish this. If the mirror is not power then omit seal modifications and reassemble.
I hope this helps.
Jeff
1989 Carrera Coupe (Black / Linen)
1981 911SC Targa (Black / Chocolate)
Old 06-18-2007, 08:22 PM
2ndTARGA's Avatar
If you search for this, there are many threads.
Once you get the glass out, there are three screws that hold the metal body to the rubber trim.
Getting the glass out depends on which version you have. Older ones have glass that is held in with press fit pins and can be pried out.
Later ones, have an internal locking ring that is accessible through a small hole in the bottom of the rubber trim. Here is a thread that might help.
PM me if you need more info.
Ron
Flag Mirror Help
1996 993 Coupe, Tiptronic, Polar Silver
1973 914 1.7 Marathon Blue Metallic - Sold
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 06-18-2007, 08:25 PM
Registered abUser
TerryH's Avatar
Once the glass is off, it's easy to see how it all disassembles. I had my mirror housing apart to paint twice in 2 months. Once because I bought a new mirror, twice because my wife put a 2 inch scratch/gouge on it a few weeks later while in the garage.
At least she felt bad. lol
'81 911SC Coupe SOLD
Old 06-18-2007, 08:31 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Last time I tried this on my 944 I had to silicon the glass on...wasn't fun. Be careful removing the glass.
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-18-2007, 08:43 PM
911Blast's Avatar
Thanks to all !!!!!!!!!!!
Thanks to the posters on this thread the mirrors are now primed and ready for the booth!
John B. - 911Blast
Old 06-19-2007, 12:02 PM
toddu's Avatar
So, you can't just buy a new rubber piece? It looks like the rubber part is what contains all the guts?
'81 SC
Old 06-19-2007, 01:18 PM
