911mnypt's Avatar
I went to replace my fuel check valve today and did not see one on the fuel pump! Am I looking in the wrong spot or does this car have one?
P-car no more
2000 F250 Powerstroke Crew cab "Growler"
2007 Honda Odyssey "The Bus"
2006 BMW 330i Manual 6 speed "The Sled"
1987 Mercedes 560SL
Old 07-08-2007, 06:13 PM
911mnypt's Avatar
I thought I would post a picture of what I am talking about...sorry for the blurry photo.
P-car no more
1987 Mercedes 560SL
Old 07-08-2007, 06:28 PM
sudo apt-get purge 930
equality72521's Avatar
According to PET, the check valve isn't used on the SC, only Carrera.
--clutch-monkey
Old 07-08-2007, 06:33 PM
911mnypt's Avatar
Mark,
I assumed it would be since everyone says you may need to replace it and it shows the check valve on Pelican's part diagrams...HMMMM
P-car no more
1987 Mercedes 560SL
Old 07-08-2007, 06:46 PM
Scott R's Avatar
Originally posted by 911mnypt
Mark,
It is, however on the 80' and specific to the 80' you don't have one per say. The check valve is built into the elongated snout of the 80' fuel pump. If you were to replace the pump with the same part number, you would have the divorced check valve. Madness I know.
At this point you really need to get a set of gauges on there to determine where the failure is. The pump is expensive, however worth it if the internal valve has failed.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-08-2007, 07:28 PM
911mnypt's Avatar
Scott,
Thank you Sir for the sound advice...I will invest is a set of gauges.
Would you happen to know what the small spring is inside the 17mm nut? When I removed the 17mm nut holding the fuel line to the pump, inside of it was a very small spring wedge sidway in the nut.
P-car no more
1987 Mercedes 560SL
Old 07-08-2007, 07:49 PM
911mnypt's Avatar
Just thought I would post a final note on this. I did replace the check valve along with fuel pump and have absolutely no issues with starting. It actually starts better that it ever has.
P-car no more
1987 Mercedes 560SL
Old 08-29-2007, 03:19 PM
