I went to replace my fuel check valve today and did not see one on the fuel pump! Am I looking in the wrong spot or does this car have one?
P-car no more 2000 F250 Powerstroke Crew cab "Growler" 2007 Honda Odyssey "The Bus" 2006 BMW 330i Manual 6 speed "The Sled" 1987 Mercedes 560SL |
I thought I would post a picture of what I am talking about...sorry for the blurry photo.
sudo apt-get purge 930
According to PET, the check valve isn't used on the SC, only Carrera.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Mark,
I assumed it would be since everyone says you may need to replace it and it shows the check valve on Pelican's part diagrams...HMMMM
At this point you really need to get a set of gauges on there to determine where the failure is. The pump is expensive, however worth it if the internal valve has failed.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Scott,
Thank you Sir for the sound advice...I will invest is a set of gauges. Would you happen to know what the small spring is inside the 17mm nut? When I removed the 17mm nut holding the fuel line to the pump, inside of it was a very small spring wedge sidway in the nut.
Just thought I would post a final note on this. I did replace the check valve along with fuel pump and have absolutely no issues with starting. It actually starts better that it ever has.
