twin plugged targa's Avatar
Can some one identify this part please
Please can someone identify the item in this trunk-
The item in question is on the left side of trunk with two hoses (fuel) going into it.
Is it a fuel breather? or vent.
I have two hoses which run to this position with nothing attached! what am I missing?
They are rubber braided hoses pos. 1/2:" I.D. maybe 3/8".
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 06-22-2007, 08:24 AM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
It looks like an evap. collector for the fuel tank....but am not sure of that.
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-22-2007, 08:29 AM
Priced-out of Porsches.
mmastro's Avatar
Charcoal-filled fuel vapor canister?
Mike
SoCal
Old 06-22-2007, 08:34 AM
Is it essential?
My hoses as far as I can see are attached to nothing! just sitting there in the front pan. Am I in any danger, or just leave as is?
Ben
Old 06-22-2007, 08:37 AM
gptom's Avatar
Def charcoal cannister. Part of emissions system. Takes gas fumes from tank when filling tank or sitting, and holds them (instead of venting into atmosphere) and then sends them to engine to be burned. Very rarely fails. check how your fuel tank is vented
Tom
Old 06-22-2007, 09:02 AM
randywebb's Avatar
Essential:
The car will run better with it correctly connected. You may be subject to inspection (lots of jokes about Fr. authorities...). If so, then it is definitely essential.
Danger:
- The question is how much danger... Fuel fumes are likely coming out somewhere and they are near the battery (!) So there is some elevated risk of a fire or small explosion.
- There is also more risk from breathing the fumes - in the garage & in the car itself. That is not a huge risk for an adult male -- but if your kids play in the garage, or if your pregnant wife is breathing the fumes, then yes the risk is significantly* elevated for birth defects, developmental abnormalities, & etc. Is it very high in comparison to other chemical exposures in the environment? Probably not. But it is easy to solve this one.
Solution:
search on fuel + charcoal + canister + emissions and various combinations of those for the many threads - BUT the layouts are for US cars...
Be sure to use hose that is approved for fuel vapors - regular PVC hose is not adequate.
* in the statistical sense
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-22-2007, 12:06 PM
Early_S_Man's Avatar
Porsche Crest
Ben,
Grady explains the evaporative control system in this thread:
tank ventilation-MFI diagrams
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-22-2007, 01:03 PM
Thanks Warren- good to see you are still out there!.
I will look into it further and see if I can get parts locally.
On a side note- just had my main engine reseal which involved total dismantling of engine- all components were 100% and clean/non worn. Engine was reassembled and tuned and now runs better than it has since I've owned her!.
Rgds Ben
Old 06-22-2007, 01:12 PM
