jkh2cpu's Avatar
911 Changing Front Calipers
Hi. I'm gonna swap out the M calipers for A calipers on my 1973 911. Does the footprint / padprint change as far as how the pad meets the disk? Or: my disk has some wear on it. Will the increased size of the A caliper pad fit outside of the wear area made by the M caliper pad?
Thanks, John.
Old 06-22-2007, 09:41 AM
Bill Verburg's Avatar
You can not just swap A & M calipers.
The A and S calipers need struts which have 3.5" mounts
M calipers have struts that are 3"
The A pad is slightly larger than an M
On a '73 the rotors are the same.
So to use an A caliper on you car you first need 3.5" struts, then it all just bolts up
Bill Verburg
Old 06-22-2007, 10:28 AM
jkh2cpu's Avatar
Right: I have the proper struts. The question remains: do I need to also change roters because of the current wear patterns. I know that the pads are larger, the question is: will the new pads overlap the current wear pattern on the rotors.
John.
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 06-22-2007, 10:48 AM
When you bed in the new pads they will mate to the rotor surface.
Tony G
2000 Boxster S
Old 06-22-2007, 11:06 AM
jkh2cpu's Avatar
I understand that they will bed... eventually, but what happens when I put them on: is there a misfit, how large is it, and is it dangerous, which gets back to the question: do I need to install new roters?
John.
John
Old 06-22-2007, 11:15 AM
Ok, now I see what you are asking.
the M pad is ~14mm shorter than the A, so no, the footprint won't match.
New rotors are cheap for that app.
Bill Verburg
Old 06-22-2007, 11:50 AM
jkh2cpu's Avatar
Thanks, Bill. I was thinking that way, but if the shape had been different, it might have worked. Yes, they are cheap. Now I have to decide: drilled, slotted, or plain. It's always something :-)
John.
John
Old 06-22-2007, 12:13 PM
John.
plain old factory is what you want
Bill Verburg
Old 06-22-2007, 12:23 PM
