Gearbox's Avatar
MFI Micro Switch question
Quick question about the micro switch mounted on the throttle body that controls the RPM Transducer. When the throttle is closed, is the micro switch "on" (closed connection) or should it be off? Thanks.
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 06-29-2007, 06:11 PM
Zeke's Avatar
I believe it's closed as opposed to open.
Old 06-29-2007, 06:17 PM
Not to be dumb but what does the micro switch really do and can you live without it?
Old 06-29-2007, 06:22 PM
The speed switch (transducer) detects the RPM and sends a signal to the micro switch. If your foot is off the gas (butterflys closed) this is passed on to the fuel shut off solonoid which ops to prevent unnessassary fuel on overun.
Yes, you can live w/o it.
'72 911T gone
'85 TVR
Old 06-29-2007, 08:11 PM
Gearbox's Avatar
Thanks for the help, does anyone know where I can source a new one? Thanks again.
Old 06-29-2007, 09:16 PM
Early_S_Man's Avatar
Porsche Crest
These are standard, full-size, microswitches that have plunger overtravel, and date back to the 1950s. Here is a datasheet:
http://www.alliedelec.com/Images/Products/Datasheets/BM/C_K_ITT_CANNON/CandKITTCannon_Industrial-Control_6764196.pdf
Pelican can get the 901.613.106.00 microswitch, but $124 seems a bit steep. A suitable replacement is available from Allied Electronics:
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=676-4199&SEARCH=&MPN=ASKHC2J04AC&DESC=ASKHC2J04AC&R=676%2D4199&sid=46859D0011B0617F
There is also an ITT/Canon HB-series heavy duty switch rated 20 Amps available from Digikey, section 'I', p. 1811, Digikey pn CKN1419-ND, for $14.11 @ qty 1, ITT #HBS2KCB4SJ055C. Also, same exact switch available from Allied for $14.86 ... here are the Allied pages and spec sheet:
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=676-4184&SEARCH=&MPN=HBS2KCB4SJ055C&DESC=HBS2KCB4SJ055C&R=676%2D4184&sid=46859D001692617F
http://www.alliedelec.com/catalog/pf.asp?FN=991.pdf
http://www.alliedelec.com/Images/Products/Datasheets/BM/C_K_ITT_CANNON/CandK-ITT-Cannon_Industrial-Control_6764184.pdf
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-30-2007, 08:45 PM
Gearbox's Avatar
God do I love this forum, THANKS Allan
Old 06-30-2007, 11:09 PM
justacoupe's Avatar
Replacement Microswitch Question
I found a replacement microswitch and have a wiring question ('73E MFI 2.4). The new switch has three wire connectors: common, norm open and norm closed.
The original only had two connections. Looking at other posts, I believe I should wire up to the common and the "norm closed" but want to confirm that. Also, the wiring diagram shows two different colored wires connected to the microswitch. However, our car has original harness (one owner) and both spaded connectors are red/gray striped wires. I marked the wires before removing them, so I know which one was mounted to the terminal below the actual "plunger" on the original switch. But I guess it doesn't matter?
Thanks in advance... and Happy New Year.
Bill Waite
Grand Rapids, MI
'65 356C
'73 911E
Old 01-01-2014, 10:35 AM
Max Sluiter
Flieger's Avatar
I think you want it norm open. You want it to close when the switch is depressed.
Old 01-01-2014, 11:33 AM
I ordered some switches here, the price is relatively cheap. https://www.allicdata.com/list.html?category_id=2291
Old 04-16-2019, 02:35 AM
