77 2.7L with very difficult problem to fix
Very difficult problem to diagnose.
Bad stumble between 1000 rpm and 2000 rpm. Very noticable at stop lights/signs. More noticable when warm.
Cleaned injectors, changed fuel Distributor. Adjusted and readjusted timming and fuel mixture. Even my very experienced porsche mechanic is having trouble with this one.
Any sugestions. I feel like i should be offering a reward to the person that solves it.
Thanks for any help
Old 06-29-2007, 09:16 PM
laughac's Avatar
Send a message via AIM to laughac
Warm Up Regulator caused this problem on my '77 last year.
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 06-29-2007, 10:17 PM
Would you give me more details on exactly what your problem was.
Old 06-30-2007, 01:05 AM
I'd start with confirming the distributor vacuum hose is blocked off or removed. Run full mechanical and set full advance at 35deg. Initial should fall into 0-5deg advance. There is a 35deg timing mark on pulley.
The vac retard really screws up timing and low rpm engine operation for smog reasons.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-30-2007, 06:46 AM
Vacume advance is not hooked up. . By setting to 35deg advance will that tell me something else. Tried further advance but makes adjusting idle impossible. At the moment the timming is set where the engine runs best for performance and idle.
Pk
Old 06-30-2007, 11:42 AM
you'll be able to map timing curve correctly at 35 total with a timing light. You may be covering up a different problem with tweaking the curve. Distributor weights may be jammed, etc?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-30-2007, 01:35 PM
Early_S_Man's Avatar
Porsche Crest
I suggest checking your centrifugal advance mechanism to see if it is sticking or is frozen. Your distributor specs are the same as 1972 - 73 2.4 engines in this thread:
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-30-2007, 07:51 PM
Start with the basics. Replace your ignition cables and go from there.
Old 07-01-2007, 12:25 AM
Wires are brand new.
I will go through the distributor to see if all is OK there to.
Old 07-01-2007, 12:47 AM
Bland
unclebilly's Avatar
Is this a California car? My 77 is and I had a similar problem a few years ago. I advanced my timing until the car started to ping under load and then backed it off slightly - it runs awesome now.
Old 07-01-2007, 06:38 AM
I had to go with slightly larger spark plug gap to get around some issues, don't know if this will help or not.
Make sure everything is "fresh" is all I can say. Wires, plugs, cap..............etc.
Old 07-01-2007, 07:08 AM
