Zink Racer
Any difference between RSA and "regular" 964 calipers?
Hi, bought an SC the PO installed RSA front calipers on. I need to buy new pads. I'm assuming from what I've read there is no difference between stock 964 and the RSA calipers but just wanted to make sure.
Jerry 1964 356, 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, a couple of other 914's in various states of repair |
PRO Motorsports
They're the same.
In fact they use the same pad as the 930 caliper.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Be advised that the setup you have is not very good for several reasons
dicounting the performance reasons, the caliper is designed for a 28mm rotor, using it on a 24mm rotor can lead to issues w/ the pistons.
Zink Racer
He also used carrera rotors and carrera calipers in the rear. I'll do a search on the specific performance reasons you mention. I assume it's been well bashed in the forum. If not, anything you can add would be helpful.
Thanks,
It's just that the stock calipers can easily overheat Carrera rotors, using the 964s which can put more heat into the rotors more quickly make even more of an issue.
Stock '84-89 Carrera rears are a good match but you do not want a p/v w/ them matched to 964 fronts
Zink Racer
Thanks. I'm assuming p/v is proportioning valve, not sure if he took care of that, doubt it.
He did add cooling ducts and block off plates to the fronts to help with the cooling issue. I had the car at the track recently and the brakes felt a bit soft. Just didn't bite very well, didn't seem to get worse during the day. I'm a low intermediate guy at this point, trying to climb my way up the DE ladder :-) safely above all. I knew the rotors were going to be due to be changed out from the PPI I had, I was planning on going to a PFC 97 pad based on my bit of research of old threads at the same time and of course bleeding the system. At this point I'll probably take it to the mechanic who built the motor and tranny and is an instructor with our club and ask him what to do....... Is the p/v a do it yourself install and what part is the right one? Do you go adjustable with this set up?
The soft pedal is another side effect of the 964 calipers, you will want a 930 23.8mm m/c
p/v(proportioning valve) should be eliminated, you could replace it w/ a nice adjustable one but unless you A/X it will be set to off. The stock p/v is in the front trunk on the line to the rear, follow the brake lines coming off the m/c
Zink Racer
Bill,
Thanks for the help. I mis read your earlier post as needing a p/v vs. wanting it gone. I don't AX the car, it's street and DE use at this point. I'll look through the receipts. I know he did something with the MC but not sure it was anything more than a stock replacement. The car is a euro 83 SC. Overall I'm gathering you are not a big fan of "upgrading" to 964 calipers. Again, I'll do some reading. I think I have a set of Carrera fronts on the 72 project that's sitting in my garage. Wouldn't be the first parts I stole off of it :-) Thanks again!
here is a pic of the 964s I used to have on my own car front ![]() back ![]()
Zink Racer
Bill, sorry to bug you again. I wanted to try and summarize my options;
If I stay with the 964 calipers I should remove the p/v if there is one, upgrade to 78+ 930 front rotors and upgrade to a 930 23.8 mm master cylinder. I assume the turbo rotors are a direct swap, just a lot more pricey :-) I see these two options on pelican for rotors: 930-351-047-00-M136 $417 each (78-80 turbo) 930-351-047-02-M259 $140.24 (81-89 turbo) Looks like the MC is: 930-355-011-03-M4 $272.25 I'm hoping the rotor option is number 2. Sounds like I could get a set of Carrera front calipers (which I think I have) and stick with carrera rotos and the rest of the setup currently on the car. I'd get the calipers I have rebuilt. Am I getting this? Sorry to be a Newbie here, you've been very patient and helpful. Hopefully someone besides me is getting some useful knowledge out of this as well.
Jerry,
For the rotor question, you need the 78-80 floating rotors. You also need the hats and T-Locks for the floating rotors. The floating rotors/hats are very spendy but worth it if you plan on a lot of track time. I've run 40-50 minute sessions on/off all day at PR and have a hard pedal all day.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
964 calipers are axial mount like the A and M that came on your car, this one happens to be a 964 rear modified for mounting on 3" centers on a 911 trailing arm. This will nmeed a '78 -'89 930 rear rotor. This mod is pretty easy. ![]() Unfortunately the 964 front is externlly the same, to use the large 32x304 930 rotors the mounting ears need to be machined off and a radial mount caliper adapter fitted, like this ![]() Then all you need is the 930 m/c If you leave your brakes as is, yes, remove the m/c and don't let the pads get more than 50% worn.
Zink Racer
Don, thanks, I was afraid of that. I'm not prepared to invest in over $1,000 for two front rotors at this point. I'm not doing that much track time, 6-7 DE's a year right now, 20 minute sessions.
I think I'll go see Chris Powell and see what those part numbers are for the calipers on my other car :-)
Zink Racer
I have these calipers off of a 72 project car I have which has all sorts of SC and Carrera bits on it. I assumed these were Carrera calipers due to the wire for the pad sensor but wanted to make sure.
It seems from this thread that I'd be better off in the near term to rebuild these if they are the right ones and use them vs. the 964 until I could change out the MC, etc. Only concern is with Carrera calipers in the rear now, the SC doesn't have a proportioning valve and it sounds like the Carrera's had one installed. Clear as mud? ![]() ![]() ![]() ![]()
If those are 3.2 Carrera front calipers then you are all set. Just use them in the front w/ your existing 3.2 Carrera rotors and leave everything else stock. If they fit over the Carrera rotors on your car now w/ pads installed then yes, they are the correct calipers for your app.
You get all the benefits of the Carrera rotor w/ none of the drawbacks of using an inappropriate caliper w/ it. Do us all a favor and measure the thickness of the spacer between the 2 Carrera caliper halves. I had it once but can't find it now.
Zink Racer
I'd be happy to measure it, what points on the caliper do you want me to use to measure from?
See the big spacer piece that goes right down the middle of the caliper, If you undo the 4 bolts holding the caliper together it will fall into 3 pieces, outer half, spacer, inner half.
Don't take it apart, just measure the thickness of the middle spacer piece,
Zink Racer
I see it, I'll do it tonight. I measured the gap between the pads right at 24mm, looks like back in the day this thing had good rotors and pretty new pads.
Too bad it's been sitting, the rotors have a light rust coating on them and I had to hammer off the calipers once they were unbolted.
I may still have the proportioning valve if you end up going this route. I'll dig thru my box.
Zink Racer
Sorry for the delay in getting this measurement, the calipers went to the rebuilder and I just got them back and mounted them tonight.
Here is the measurement, looks like .444 inches or roughly 11.3 mm's if I'm reading the caliper correctly. I put on the calipers and bleed the system tonight, will check everything out tomorrow and put it on the road. A fellow Pelican is sending me the lines and proportioning valve from an 84 parts cars. For now I have PFC 97's in the fronts and some softer pads in the rears. I'll see how it feels with those and install the other lines when they come in and put the 97's in the rears. It was a bit of a pain getting the hard lines off my parts car. The 964 calipers had to be installed with several washers at the hard line to soft line connection and the holes were elongated on the calipers to get them to bolt on. I'm glad that stuff is off of there at this point. ![]()
Thread Tools | |
Rate This Thread | |
