450knotOffice's Avatar
Question Question about alignment.
For a couple of years now my '84 Carrera car has been...darty and pointy... (for lack of a better way to describe it) to the point of being a little unnerving at speed when the road gets bumpy.
It has very, very quick reflexes on turn in and will take a set beautifully, and hold it steadily. While in the turn, the car feels really good. However, during the transition phase from a turn in one direction to a turn in the other direction while at speed, the car seems to exhibit a little tendency to want to over-do the initial turn in, which I have to correct a little before the car finally settles down and takes its set. It's not a confidence inspiring feeling. It almost feels as if it would want to snap around if I weren't careful with it. Again, this is only during the transition from turn to turn (or during quick lane changes at speed) and is most noticeable at high speed (like 70 mph+. At slow speeds, I don't really feel any of these tendencies. It feels good from side to side).
It feels great while established in the turn, just not so good in transition at high speed. Also, the car really wants to move around a bit while at speed on anything other than a smooth road and if I apply brakes at speed it becomes a handful again. Also, I have the factory tail and front spoiler. The tires are fairly new S03's rear and older S03's front. They're all in good shape.
I hope I'm making sense here. The suspension was (mostly) rebuilt back in the Spring of 2005 with new bushings, ball joints, 22/28 mm t-bars, Bilstein Sports, turbo tie rods, Rennline strut brace, good wheel bearings, bump-steer kit, etc. (the trailing arm bushings were not replaced due to the difficult access to the mounting bolts on the torsion bar tube, but they looked OK from what I could see). The steering system is tight as a drum with no slop whatsoever.
So, I'm guessing it might be my alignment settings. Could the front or rear toe be set a little too aggressively? Would toe adjustments make a difference in stability for this car?
Here are my corner balance numbers:
LF - 501 RF - 504
LR - 814 RR - 814
Alignment settings:
Camber:
LF -1 3/8 degrees
RF -1 3/8 degrees
LR -1 1/4 degrees
RR -1 1/4 degrees
Toe:
Front - +15'
Rear - +20'
Caster is all the way back, I believe.
Ideas?
Old 07-03-2007, 11:22 AM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
I'm sure they checked it during your corner balance but is there any preload in your sway bars? From what I understand they are disconnected during the corner balance.
I can't imagine the shop you took it to wouldn't have mentioned it.
-Jess
Old 07-03-2007, 11:32 AM
rnln's Avatar
Scott,
I am not sure if you have the problem I had before (BMW, a daily car) when I had it aligned at a race shop years ago. This guy was famous among those racer guys. After he's done, I had wonderful oversteer, which made me smile at any corner. However, at high speed, it can get scarry, especially uneven highway surface. It jerks alot left and right. The tires were worn straight/evenly and nice but very quick. I brought it back there several times within 2 months. By 2 months, my 2 rear tires were bald and there are lot of "black mud" on my rear bumper corners every day. By that time, I knew that he had my rear wheels toe-in too much. I brought the car to another alignment shop, which is a normal shop with a hunter machine (not specify for race). With couple adjustments, the car was back to normal and the next set of tires lasted over 2 years.
I am not sure if you are having the same problem but maybe you might want to look into your alignment.
Fat butt 911, 1987
Old 07-03-2007, 11:40 AM
Try less toe-in ( I guess "+" indicates toe-in, not toe-out ,.... right?) in the rear, and maybe check "thrust angle"... how "square" the the car is against all 4 corners. Make sure the chart with + settings truly indicate toe-in. If toe-out ... then that could be your problem right there.
Another hint ..... I also find spooky handling whenever new tires are put on...either in pairs or all 4. Usually takes me 700 miles ( ! ) for that squirrelly-ness to disappear. Try old tires in place of the new ones ( borrow rims/tires as a test ?) that are now on the rear.
Otherwise your settings would not raise a red flag of the symptoms you're seeing.
IMHO....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-03-2007, 11:49 AM
Thanks guys. Wil, I assume that the rear toe settings are for toe-in. Is it even possible to get 20' of rear toe-out with these cars?
Old 07-03-2007, 12:11 PM
I'm not sure what the total allowable range of adjustment is for our cars, Scott.
But..if thrust angle is "off", then one side may truly toe-out ( relative to direction of motion), and the other side would be severely toe'd-in...even if spec was for toe-in for each side. Like those old Chevy Nova's that "crabbed" and looked like they were always turning...but actually going straight ...right in front of you along the highway as you followed behind.
You're probably too young ... LOL !
- Wil
Wil Ferch
Old 07-03-2007, 01:52 PM
Senior??? Oh very well
fly4val's Avatar
I found a big difference when I replaced the tires, 10-15 year old Yokies with newer more all season compounding (same mfg/sizes)....found a bit of a tail wag but nothing too radical. Bought my tires at Discount and go there about 4k miles, have them demount the tires and swap left for right same as when I ran SCCA....
Prior to this I had had complete turbo tie rod assys installed along with the bump steer kit. The alignment following this found a LR broken sway bar bracket and a possible minor bend (according to the alignment tech) in the RR trailing arm (still on the car).
I've just done new shocks so hopefully that isnt too big a deal for 1300 miles.
Unfortunately, I'm in the process of moving to a small town in western Colorado on Monday...so am going to have to live with what I have until I can find the time and the money to drive over to Denver or some place where there is a decent alignment shop/dealer...hopefully someone that can do Pcar alignment and corner balancing...
Old 07-03-2007, 02:15 PM
How was it prior to these mods?
Joe
Old 07-05-2007, 09:59 PM
I've been having a discussion with Tyson Schmidt via PM and he seems to have nailed it. It all started when I replaced my worn out rear S03's with new S03's. He said it sounds like the back is steering the front a bit due to the softer rubber on the new tires not harmonizing well with the old, harder, worn rubber on the fronts. He said that's why he always tells people to replace all four tires at once, even if the fronts are still showing useable tread left. He said old and new tires, even if they are the same brand and model, don't mix well on 911's.
The car handled perfectly before I changed out the rears. I simply forgot that it had becuse it was a while ago.
Old 07-06-2007, 09:22 PM
Navin Johnson
TimT's Avatar
+ toe out in the rear is a recipe for disaster, though it appears you just have a tiny bit of static rear toe out.... whos knows whats happens with the rear toe when the rear is loaded from braking or acceleration.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-06-2007, 09:56 PM
rnln's Avatar
Scott,
I am with Tim and other about rear toe. The explanation makes sense but does our car really that sensitive, maybe I am too naive. If you decide to throw them out, I'll take them and will enjoy them
Another thought, might not be related at all. Once I flipped the front tires (inside edge to out side edge) because the inside edge worn more do to too much negative camber. THe result was expreme tramlinning.
Fat butt 911, 1987
Old 07-06-2007, 10:28 PM
RE: +20' toe: Yea, I noticed that too. I wonder if my alignment guy actually meant -20'. That would make much more sense. I don't even know if you can get +20' toe out in back.
Old 07-06-2007, 10:31 PM
rnln's Avatar
time to spend 1/2 hour to set up string method at home. Just a reminder, tomorrow is saturday if you forget
Fat butt 911, 1987
Old 07-06-2007, 10:33 PM
Yea. Time to learn the method, I guess.
It'll have to wait until next week though. I work over the weekend.
Old 07-06-2007, 10:36 PM
Navin Johnson
TimT's Avatar
sure you can.. you can F$#% up the rear alignment to the nTH degree...have a touch of toe in dialed in, or better yet have it set to spec, which I dont remember off the top of my head
On edit: set a touch of toe in, and then adjust camber.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-06-2007, 10:37 PM
Chuck Moreland's Avatar
I'd definitely get clarification on the toe. If it is 15 minutes and 20 minutes toe out, then there is your problem.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-06-2007, 10:52 PM
Thanks guys. They offered to throw it up on the laser alignment rack and check the settings.
Old 07-06-2007, 11:03 PM
jevvy's Avatar
Just look down the side of the car and line up the leading and trailing edge of the rear tire with one eye shut - with a bit of comparing side to side front to back you will see quite quickly if the wheel is toed in or out.
'89 3.2/3.6 coupe
Old 07-07-2007, 12:47 AM
Although Tyson's suggestion to replace all 4 tires is sound...do recall I said this within 3 answers of starting this post--->
"Another hint ..... I also find spooky handling whenever new tires are put on...either in pairs or all 4. Usually takes me 700 miles ( ! ) for that squirrelly-ness to disappear. Try old tires in place of the new ones ( borrow rims/tires as a test ?) that are now on the rear."
- Wil
Wil Ferch
Old 07-07-2007, 10:13 AM
Yes you did. However, the rear tires have well over 700 miles on them now. Probably more like 2000-ish. The spooky handling is still there so I initially discounted the rear tires as a cause because it never dawned on me that mixing old and new tires could cause a problem like this, considering that they are the same type. I was mistaken.
Thanks for all of the info guys. I really appreciate your input.
Old 07-07-2007, 10:12 PM
