JTL JTL is offline
JTL's Avatar
Question elephant front pbb install - spacers?
I noticed some binding when tightening down the front mounts. Is there a specific spacer to be used in order to eliminate the binding or just trial&error.
Thanks, jt
-84 Carrera
Old 07-14-2007, 09:47 PM
rlh930's Avatar
Did you get the low-friction control arm mounts? If not, you probably need them. If so, they are a little tricky to install. Careful reading of the instructions and a little fiddling should eliminate any binding.
Roger
'87 930
'73 911T
Old 07-14-2007, 10:14 PM
JTL JTL is offline
JTL's Avatar
Arrow
You mean the low friction rear mounts? No, I reused the old ones figuring to get by with them. There is only a little binding when the front mount bolts are tight. I would bet adding a pair of spacers in the front would eliminate the binding.
The setup now is probably good to go as is but I want it perfect or at least very close.
jt
Old 07-15-2007, 07:24 AM
Todd Simpson's Avatar
The low friction mounts are both front and rear.
I bought them when I did my install...no regrets and they eliminated the binding as I tightened things up.
Old 07-15-2007, 12:22 PM
AutoBahned
RWebb's Avatar
What is the approved way of doing this nowadays? Last threads I saw were a while ago, but involved putting epoxy or similar (loctite bearing mount cmpd., or JB Weld) in there instead of shims...??
Old 07-15-2007, 02:35 PM
