Speedo Sensor..
Does anyone have a photo or an explanation as to the direction the sensor goes in the transaxle.. Think i may have it in backwards.. Confused how the little clip holds it in.. there is a metal contact in the center on one side/? cant remember how it came out..
Thank you |
Hi, the plain, flat, plastic surface goes on the inside with the two lugs toward the outside. The clip rests in the middle of the sensor to keep the whole thing in.
Cheers, Mike
thats how i have it in there.. was worried it was right.. Its not working anymore... have to check the wiring I guess
thank you |
PS, do a search on speed sensors, there's lots of info and checking procedures to try before buying a new one.....these things are not cheap.
Mike. |
Slumlord
Rotate the wheels (both) and put a test light across the two wires. It will flash if the sensor is installed properly.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
