blank slate
+1 for worn bushings. After replacement, 1st and 2nd are still resistant, but shifting is much more precise.
1979 Porsche 911SC 1969 Porsche 912 (gone but not forgotten) |
drag racing the short bus
The Terror of Tiny Town |
Sports Purpose 911 Driver
and speaking of gearboxes probably in need of a rebuild.. is yours holding together Jack?
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
I had a full rebuild ++ built around a 3.4L future install.
glad i went that way instead of a G-50
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I have never driven with one but... my guess is that if you could get a WEVO dog box, it would be the cat's pajamas. I have raced against them, and they are advantageous compared to a normal 915. But it will cost you. Not sure whether they are available any more as new though.
Another approach was taken by one of our local racers... he rigged up an EMCO (used in DP cars). Not cheap. Anothe route is to just buy a modern Porsche factory race car and put the parts in your street car. Maybe not practical.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
Boost Freak
Yep, guitars and cars and wheelin down that long lonesome highway ! Sounds like from everyone's advice that a bushing kit is money well spent. I forgot to mention, 3rd gear is kind of funky to find at times as well.
82 Porsche 930 Euro, black, 31K miles. Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Another comment about non-sycnchro transmissions whether sequential or not: most of them are racing oriented and therefore close ratio, so less difference in gear speeds during shifts and less 'need' for synchros.
I remember the first drive I had in a '79 SC in about '80 or '81, so a pretty new car. I could not believe how nicely it shifted, I came out of british stuff which shifts pretty nicely, but even if the 911 had longer throws than my MGB, it just had a beautiful feel. I remember shifting it just to feel it. I also remember mid '80s BMWs having very slick feel.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
http://hargettprecision.com/index.php?cPath=35
Gary R. |
Also, replace your tranny and engine mounts, perhaps with sprotier versions. Keeping everything lined up with the linkage made a big difference for me!
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Good discussion.
A feature of a sequential transmission (like a bike) is you CAN’T skip gears. This means every gear change has minimum rpm difference. With only slight power interruption (many use an ignition/fuel interruption system), there doesn’t even have to be de-clutching or lifting on the throttle. I agree about straight cut gears, they are too noisy for normal street use. The choice of straight cut gears (noisy but strong) compared to the various angle cut gear forms doesn’t have anything to do with the choice of engagement (dog, syncro, etc.) Some later G50 types (G64 …Japanese G97/01) have changed the syncro angle (to 15°) to reduce the effectiveness and allowing faster (sequential) shifting. I understand some electric systems have 2 mS shifting. I think the auto industry is going away from automatic transmissions with clutches, planetary gears and torque converters. It seems the choice is regular mechanical transmissions (10+ speeds), dog engagement (no syncros), electric shifting (sub-millisecond) and all computer controlled. I think the reason is fuel efficiency and emissions - AND it gets everything under the control of the computer. I think the RS Spyder may lead here. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
I agree Grady. The systems with 2 clutches, such as the VW DSG tranny, with one always engaged is appears to be the future of transmissions.
http://en.wikipedia.org/wiki/Dual-clutch_gearbox |
Helical dogboxes are popular with the Subaru crowd. Quiet for cruising at the cost of some gear strength, but fast shifting.
