KatoKato's Avatar
One last A/C removal question..
Last year I removed the A/C in my 86' 911:
A/C Removal has begun - a few questions though
One last thing I was wondering about was the wiring in the smuggler's box.
The unplugged connector with the brown / red+white wiring I think went to the evaporator.
Can I remove and/or unplug any of the other wires in the photos?
Thanks in advance,
Kato
Old 07-18-2007, 04:32 AM
aj88cab's Avatar
The other connector goes to the thermo (bi-metallic) switch located under the passenger side floorboard. You can disconnect it or leave it. Probably not worth the trouble to remove it though. You or someone might want to reinstall the AC one day.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 07-18-2007, 06:29 AM
Originally posted by aj88cab
...Probably not worth the trouble to remove it though. You or someone might want to reinstall the AC one day.
That sucker weighs at least .035 pounds ! I removed the bi-metallic switch (and wires) and fashioned a "plate" to cover up the hole in the floorboard.
Old 07-18-2007, 07:13 AM
jevvy's Avatar
I have just removed the cable too and you can do it without cutting or removing the tank by unplugging it from the bundle of wires near the fuel filler and also to un-hook 1 earth from the same place.
Once these are unplugged you can pull the rest of the cable through into the smugglers box.
'89 3.2/3.6 coupe
Old 07-18-2007, 07:20 AM
Dont' cut anything! Even if you don't remove the bi-metallic switch, unplug the wires from it and put it back in place...
Old 07-18-2007, 07:26 AM
KatoKato's Avatar
You are referring to the connector black into white with the brown+green+red/white wires? (not the one behind it)
Re: the one behind it - It's the one where you can see one red wire going in and it plugs into that silvery metallic thing. What is that one for?
Kato
Old 07-19-2007, 05:42 AM
KatoKato's Avatar
Originally posted by KC911
...I removed the bi-metallic switch (and wires) and fashioned a "plate" to cover up the hole in the floorboard.
I did the same.
Old 07-19-2007, 05:46 AM
aj88cab's Avatar
Kato
That is the A/C evaporator motor relay. It too can be disconnected and removed.
Old 07-19-2007, 06:11 AM
KatoKato's Avatar
Ok .... so .... all of the wiring in the pics is A/C related and can be disconnected and / or removed?
Old 07-20-2007, 08:20 AM
aj88cab's Avatar
Yes, that is correct.
Old 07-20-2007, 08:32 AM
KatoKato's Avatar
Ok ... removed the wiring to the console and the relay. Incidentally I had cut the wiring from the console and didn't realize that it was basically sitting inside the grommet at the bottom of the smuggler's box.
I decided to leave the wiring from battery/ground just in case I want to wire in some electronics of some sort later.
My next question is regarding the other side of the smuggler's box.
Other than the cut A/C hose & steering thing-a-ma-bob, is there anything A/C related in the photo?
Cheers,
Kato
Old 07-23-2007, 02:27 PM
KatoKato's Avatar
Re: pic in previous post...
Can anyone tell me what those two copper lines are for?
Is that black wire for the fuel pump?
Kato
Old 07-26-2007, 12:31 PM
They're brake lines...I wouldn't remove them
Old 07-27-2007, 04:51 AM
