Factory Widebody question
Hello-
Is there away to determine if a widebodied car is factory? It is a 1979 911. Any help would be appreciated.
Old 07-18-2007, 06:56 AM
scarceller's Avatar
I own a 1984 Carrara Factory Widebody and at first glance you should look for the following:
Cross Drilled rotors with red brake calipers.
Green struts (shocks) in the front, Bilstein struts.
If you do not see this suspect it may not be factory Widebody.
To be 100% you need certificate of authenticity from Porsche.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 07-18-2007, 07:01 AM
Super_Dave_D's Avatar
I think the TL was first available in 84 so it would be a conversion. Others will chime in im sure.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 07-18-2007, 07:02 AM
Bill Verburg's Avatar
The first year that the widebody was available as a factory option(M491) was 1984.
There were a few widebodies done through the factory special wishes program before that.
Easiest clues besides the option codes are 930 brakes, especially in the back where the correct 930 trailing arms will mount the calipers in the trailing position rather than the leading postition used on 911 trailing arms.
Bill Verburg
Old 07-18-2007, 07:07 AM
scarceller's Avatar
Also, not 100% on this but I think Porsche did not offer the M491 (widebody option) till 1984. So unless this was a 1979 Turbo in a prior life, it most likely is NOT a factory widebody.
See this group for details:
http://autos.groups.yahoo.com/group/Porsche911FactoryTurbo-LookCars/message/3204
Sal
1964 356SC (SOLD)
Old 07-18-2007, 07:19 AM
