trailing arm help
Was wondering if trailing arms off a 82 911 Will fit on a 1970 911T?
derek
Old 07-19-2007, 09:44 PM
Very nicely, yes,..
You will need to deal with the rear swaybar droplinks and stub axles to match CV joint patterns.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-19-2007, 09:52 PM
barney911rs's Avatar
I'm in the process of putting some late Carerra aluminum arms on my 73, so your situation should be fine as well. I already had after market sways that connect to the spring plate rather then the ball on the steel arm, so I can not answer that question for you. I'm also doing coil-over shocks and 935 spring plates, so I'm going well beyond stock. If you have any specific questions post them here.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 07-19-2007, 10:49 PM
Todd Simpson's Avatar
There are further issues related to the shock mounts on the trailing arm. Details are in the link below.
I now run my shocks with rubber dust covers as the metal ones rubbed on the shock body, creating some very twitchy high speed handling.
http://members.rennlist.org/911pcars/AlloyContrlArms.htm
Old 07-21-2007, 09:06 AM
