RichF's Avatar
WEVO coupler install question.
ok installing the coupler is a no brainer, well it turned out not to be. Right now I have male end of the wevo coupler pushed to far into the female end of the "shifter shaft", so now I can't line up the holes for the set screw on the other shaft and the female end on the "shifter shaft" is way to tight to get the male end of the coupler out. So does anyone have any input or experience on what the hell i should do.
Thanks, Rich
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 07-21-2007, 12:50 PM
AirCooledExcellence's Avatar
The coupler is a tight fit, you need to open up the hole in the shift rod slightly. I used a large screwdriver in the slot. Of course it's advisable to do this before you install it
I think your best bet is to spray it with penetrating oil and try and tap it back out of the shift rod.
Good luck!
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 07-21-2007, 01:51 PM
RichF's Avatar
thanks for the input im gonna go at it agin tomorrow
Old 07-21-2007, 02:10 PM
