Downerman's Avatar
2.7 Script - Where exactly does it go?
Ok, I know it's on the right side of the grill about center I believe but then again I am not sure so......... does anyone know the exact location for the 2.7 script on the engine grill? For what it matters and I don't think it does it's a 74 Carrera.
Old 07-24-2007, 02:28 PM
mark 74 carrera's Avatar
I will measure mine and get back to you.
Mark
Mark Isaak
1974 Carrera Targa - Light Yellow, Being driven
1974 Carrera Targa - Orange, Being restored
1974 Carrera Targa - Lime Green, Being pampered
2017 Macan
Old 07-24-2007, 04:13 PM
Hope this helps
I also had the same question about a year ago and I think the bottom of the script plate needs to be on the 6th grill bar from the bottom, centered between the two vertical grill bars on the right . . . . did I confuse you already.
I was going to provide a pic but I can find the add photo feature on this new format.
M-74
Old 07-24-2007, 04:34 PM
Mine is located between the 7th and 8th horizontal grill bar form the top. It is located horizontally 2.25 inches (that is the 7 in 2.7) is 2.25 inches from the outer most vertical cross member.
Hope this helps, Mark
Mark Isaak
2017 Macan
Old 07-24-2007, 07:02 PM
