NASA instructor
bornrich's Avatar
Shift knob working itself loose
I have an aftermarket shift knob that uses a crush sleeve (like the stock one). I purchased a new crush sleeve (from our host), inserted it in the shift knob and using a small pine board as a buffer, pounded it on. Now after a day or so, the knob is loose, lifted about 1/4 to a 1/2 inch and has the be pounded down again. It has done this several times. What am I doing wrong?
I have also tried twisting it around a couple of times before hammering it down but in as little a few hours it is loose again?
I may just bite the bullet, drill a small hole and insert a set screw but I thought I pick the collective brain of the board first.
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 07-26-2007, 05:08 PM
NASA instructor
bornrich's Avatar
Bump. Anyone with any insight on this problem?
Matt Rich
1999 BMW 540i
2011 BMW 535i
Old 07-30-2007, 03:25 PM
19 years and 17k posts...
azasadny's Avatar
I gave up and used Super Glue on my shift knob and I just drove the car 600 miles without it working itself loose...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-30-2007, 03:29 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
you could try wrapping the shaft with duct tap to tighten the connection. otherwise i would glue it. im partial to momo, allen set screw type nobs. they stay tight for a while but even they need tightening once and a while
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-30-2007, 05:37 PM
NASA instructor
bornrich's Avatar
I think I will try the duct tape method first. Thanks
Matt Rich
1999 BMW 540i
2011 BMW 535i
Old 07-31-2007, 04:43 PM
My Momo knob with 3 set screws kept working loose on my aluminium Rennshifter shaft. Despite the steel screws actually biting into the aluminium! I tried loctite and even that was only good for a short period.
I finally wrapped some tape just under the knob to act as a platform for the knob and then reappled loctite to the set screws. So far it's holding well.
If this fails then I'm back to the screw on knob.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 08-03-2007, 05:13 AM
