Reusing the nylocks and aluminum washers could and will eventually result in oil leaks.
The nylon ring in a new nylock keeps oil from seeping along between the stud and nut threads, and the aluminum washer seals in the oil between the nut and rocker cover. Rocker cover nuts only go on snug not tight, so the nylon ring in the nylocks keeps them from coming loose from vibration. No problem reusing them right after servicing so you can use the car, but replace them asap when you can. One at a time without removing the cover would be easy. |
Thanks JFairman - I'll give it another shot as soon as I can weasel a few hours away ... I'll post the improvement (hopefully!) in speed and accuracy when I'm done.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
changing the starter on my 1989 911 Speedster. OUCH !
The horror.......... |
I do not believe that the nylocs and washers offer much in leak protection. I believe that it has to do with how the cover gasket seats with the cover and the bolts at their base. I say reuse and let us know how it goes. Could be a nice experiment to see how long they last without leaking.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Used Up User
![]() Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Make damned sure the covers are true....baseline start...go from there (insofarsas leaks..)
Best of luck
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
UFLYICU
I have reused the sealing washers by flipping them over. If you look closely, you'll see the indentation made by the nut. The nylocks should be OK to reuse a couple of times. I wouldn't trust them after a couple of times.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Just finished 2nd valve adjustment. 4 hours, and I think I got it reasonably right. Mostly backside method, unless the valve was way out of whack. I made some feeler gage stiffeners / extenders that made the task much more "pleasant" (for me anyhow)...
![]() A few of the old nylocks are indeed drooling oil - garage smells yummy....
Yep,..I've passed on this task...didit,..felt ok with it after learning the nuances (and access headaches)..weird working "blind"......SO: decided to budget out the required costs for this task, to be done by the pros....decision made....
I can sleep at night now... Best,
Damn!! I wonder why I look for Zoanas' posts...that frikin' avatar is the best out there..
Holy smoke!!
I have a tool that makes adjusting 911 valves easy and painfree. It's a retired Italian mechanic named Tony who spent his entire working life repairing Porsches.
I give him $80 and it's done in less than 3 hours. |
Southern Class & Sass
Update: BACKSIDE RULES!
![]() Finished the valve adjustment today. Went through every valve one last time using the backside method - again. All of them checked out. Buttoned everything up, and gave the key a turn. The car fired right up and it ran perfectly. Not a single ticking valve. Not a single oil leak. Of course, then I noticed I have a major fuel line leak. So now I have to fix that…
Dixie Bradenton, FL 2013 Camaro ZL1 |
