Send a message via Yahoo to itsa6911
Points---ignitor ???
Hi,
I want to get rid of the finicky points in my 73t 2.4 w/Zeniths and go with the pertronix ignitor,,My question is which one ?They offer 2 for 73..
They divide the 73 & 73.5 at May ?
My vin is 0327
Bosch dist 231 169 008
I have the MSD 6A.
and MSD Blaster SS coil
Magnacore red wires
Hope that covers everything.
Thanks in advance.
1977 911S Turbolook 3.0sc
1973 911 t targa
1968 Firebird convertible
1968 911 t-(Burnt)
1970 Chevelle-(SOLD)
Old 07-28-2007, 08:00 PM
i installed 1867
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-28-2007, 10:30 PM
Question
Pertronix doesnt offer the igniter for the Bosch 008 distributor,,, and I'm not sold on the Crane(search button has revealed good/bad). With the MSD 6 A and SS coil I'm running I seem to quickly burn up the points...Is the aftermarket ignition causing this or Is there a resistor I'm missing that could remedy it ? If so What type and where does it install ? Any input appretiated,, P.o. installed the system as per the MSD diagram.. Thanks.
1973 911 t targa
1968 911 t-(Burnt)
Old 08-01-2007, 07:56 PM
I have no hard answer to your unusual problem.
I dumped the resistor Beru plug wires and stock rev limiting rotor. I use magnacore wires and the 72-77 VW non-rev limiting rotor, pelican pn Bos-0403. If your going to a local parts store then the 04038 pn made by Bosch should suffice.
I also have the SS MSD coil without any resistor. I completely rewired the stock positive MSD feed w/10ga marine.
A wild guess is that the points have a poor ground if you've eliminated the problem, imo, Beru wires and rev limiting rotor already.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-01-2007, 11:39 PM
Roninlb
that looks like the non rev limiting rotor Im using, so bad ground as in the eng/tranny ground strap ?
Thanks...
1973 911 t targa
1968 911 t-(Burnt)
Old 08-02-2007, 03:39 AM
Originally Posted by itsa6911 View Post
Roninlb
the points are grounded inside the dizzy. There maybe a crimp connector at the wire between the movable point plate and the housing. "Crimp" in like a piece of brass tube squashed at both ends instead of solder. The dizzy body is mostly grounded through the bolt and fastener unless there is a ground wire attached to the outside housing.
again, only a wild guess.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-02-2007, 04:03 AM
