Throw it on the ground!
Back-up switch question
Will be installing a back-up camera that will feed to my Nav screen soon so I need to find the best location to tap into the back-up light circuit.
Is the switch on the tranny on the (-) ground side or (+) side of the circuit? Thought I'd run across the answer on a thread but could not find with a search
I'll need to tap into the (+) side to activate the camera. Best location will probably be at the tail light.....but I'll need run a lead to the Nav dock in the trunk.
Any chance of finding a hot "switch activated" tap location in the trunk?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-29-2007, 06:12 AM
Wiring connections...
Mark,
If your '87 has similar wiring diagram to early Carrera or SC's, the're many connecting points in the trunk you could tap power: (a). Ignition switch OFF: fuses for interior lights, and warning light for heated windshield. (b). Ignition ON: There several points, fuses for bak-up lights, air blower relay, sunroof, windshield wiper, cigarette ligther, and fuel pump relay. Use a test light and you'll find these points.
The 915 trans back-up light switch is a ground (-) contact switch. The 3 fuses at the rear are also a good source for power. Hope this will help you.
Tony
Old 07-29-2007, 09:40 AM
Tony, thanks for the suggestions and confirmation that the back-up switch closes the ground. Finding a power source in the trunk is not a problem......what I need to find is a back up switch powered circuit to trigger the Source Selector on the LCD Screen from Nav to Back-up Camera when I shift into reverse then back to Nav when out of Reverse. Not sure if tapping into the low side of the back-up light circuit fuse will work????
Mark
1987 911 Coupe
Old 07-29-2007, 10:45 AM
Less brakes, more gas!
euro911sc's Avatar
Just out of curiosity... do you actually have trouble seeing back there? Or is this simply a neat gadget exercise?
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-29-2007, 10:56 AM
-michael
Both but clearly more of a gadget excercise since the nav screen has video camera input.
Mark
1987 911 Coupe
Old 07-29-2007, 03:35 PM
Gave you the Wrong Information
Tony
Mark,
I gave you the wrong information about the back-up ligh switch. The 915 back-up light switch (F4) carries power from the ignition switch to the back-up lights. So F4 (back-up light switch) is a + on/off switch for power not ground as previously stated.
I'm surprised nobody noticed the error. Sent PM too.
Tony
Old 07-29-2007, 07:34 PM
