Exclamation Urgent Clutch alignment tool needed
Help. I need to get the motor back in tomorrow, I'm so close... but need to borrow a clutch alignment tool. If you have ever done a clutch job you probably have one. Can I borrow it for a day? I'm in Pleasanton and will drive anywhere to pick it up tomorrow. Repond to this post or call me at home in the morning at 925-426-0078.
Thank you!!!
Caevon
Old 07-28-2007, 10:30 PM
barney911rs's Avatar
I'd love to help you, I have two, but there are almost 2500 miles between us. Good luck.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 07-28-2007, 11:00 PM
Hilbilly Deluxe
emcon5's Avatar
Drive to pretty much any auto parts store, I am 99% sure it is the same as a VW. Should be about $5. To make sure, take your old clutch disk with you.
Tom
82 911SC Coupe
GTI Cup #43
Old 07-28-2007, 11:01 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
edited:
I can't find the damned thing, of course. You should be able to find one at Kragen.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-28-2007, 11:09 PM
Kragen? Same as VW? Wow cool. Looks like I might make it after all. Thunderhill, here I come!
Old 07-28-2007, 11:26 PM
I have never needed an allignment tool.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-29-2007, 04:10 AM
MBEngineering's Avatar
HI caevon, If you put your new clutch on so the bolts just hold the center-plate and you can just move it with your finger, through the throw out bearing, then put the box back on and bolt up the box , now through the starter hole tighten up the clutch bolts a little more to hold the center plate in position , turn the flywheel round through the hole in the top of the bell-housing to get to the other bolts , then remove the box and tighten up evenly to pull the pressure plate to the flywheel. and do NOT forget the RING GEAR of the old pressure plate, to put on the new one.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 07-29-2007, 11:52 AM
jevvy's Avatar
regards mike
+ 1 with this trick, mike knows his onions!
Remember all you need to do is get it aligned enough so you can get the box on - the first time you depress the clutch the friction disc will center itself anyway.
Good luck.
'89 3.2/3.6 coupe
Old 07-29-2007, 11:59 AM
Make Bruins Great Again
Por_sha911's Avatar
I got one at Autozone for $3.99.
Amen to the ring gear!!! Ask me how I know
Joe
Old 07-29-2007, 01:28 PM
