fred cook's Avatar
Cool Sc A/c........
Which would be more bang for the buck to replace? The evaporator or the condensors? I have already replace the compressor with a Sanden unit, added a Pro Cooler and rebuilt the hoses with barrier hose. Now looking to go the next step.
Thanks,
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-30-2007, 09:29 AM
scottb's Avatar
Have you considered ADDING a condenser/fan assembly in the front left fender? That will give you the most improvement, and bang for the buck!
1984 Targa
Old 07-30-2007, 09:39 AM
Barrpete's Avatar
One of the big deficiencies in Porsche AC systems is lack of condenser capacity. So anything that improves condensor efficiency will help. You've already added a procooler, either adding another condensor or upgrading an existing one will help as well.
I would think the condenser would make more of a difference than the evaporator. It's also a little less work to remove/replace one of the condensers than the evaporator.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 07-30-2007, 10:41 AM
I used a griffiths additional condenser with a fan. It's mounted inside the back left fender
but, I also changed out the evaporator, hoses and compressor. Works gar better than any stock system for a 1973 model 911.
Old 07-30-2007, 11:17 AM
Biggest bang...fan for the condenser! Do this before you get another condenser. Do a search.
Old 07-30-2007, 11:24 AM
