Ducst4's Avatar
ignition switch (key problems)
Hi
This just happened to me, first time ever. I put the key in the ignition and the key would not turn. Just like if it was not the right key. I played with the key for 5 minutes gentle back and forth and it turned. Could the ignition switch get "loose"?
_______________
Ducst4
1989 911 3.2
Old 07-30-2007, 05:08 PM
First thing to try is direct spray lube injected into the key hole. Use liberally. Complete assembly is made from cast aluminum, and I think it "galls" from lack of regular lube. And the last thing you want to do is replace the entire unit at 500 dollars. I use REM (as in Remington) lube, which is made for lubricating firearms. There are a number of locks, sears, spurs in the action of O/U shotguns. Many posts here re this problem.
1987 Carrera 3.2
Last edited by sig_a; 07-30-2007 at 06:50 PM.. Reason: Thought of something else to add.
Old 07-30-2007, 06:47 PM
Zeke's Avatar
I assume the steering wheel was not against the lock.
Old 07-30-2007, 07:29 PM
Super_Dave_D's Avatar
Oh here we go....wd40 or not to wd40!!
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 07-30-2007, 07:58 PM
Designer King
Paulporsche's Avatar
It could be the lock mechanism or the key. Try the lube first, then another key, then replace the switch, if necessary.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-31-2007, 05:01 AM
911SCfanatic's Avatar
Had this problem 2 weeks ago before just as I was leaving for a long weekend. I was stuck in my garage with 500 miles to drive that day. WD40 and problem gone.
Bill G.
'68 911 Ossi Blue coupe
Old 07-31-2007, 05:43 AM
