MFI mixture adjustment "click" question
Hi,
I have a doubt, in the CMA manual says that when you adjust the mixture you can turn only 2 or 3 clicks at a time, why?
What happens if you turn it more clicks without starting the engine?
Thanks,
Josep
1967 911 Soft Window targa
1969 911S 2.0 targa
1977 911S Sunroof coupe
1979 911 Turbo 3.3
Old 08-02-2007, 09:12 AM
PRO Motorsports
Tyson Schmidt's Avatar
Because one click on the main rack makes a large change. You could turn it more, but it will likely make it more difficult to find the sweet spot.
Keep track of every change so you can go back if you make things worse.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-02-2007, 09:18 AM
FenderBender's Avatar
Neither of mine click. To my surprise. Is this something to be worried about?
Mike
'99 Isuzu VX, 2005 Audi A4 1.8T Quattro
'96 BMW 328ic
'73 911T Targa SOLD
www.flickr.com/photos/fenderbender813
Old 08-02-2007, 05:25 PM
Friend of Warren
My experience has been after a lot of use the rachet mechanism gets old and no longer "clicks."
Kurt V
Old 08-02-2007, 05:47 PM
Ok no worries. Thanks, Kurt
Mike
'96 BMW 328ic
'73 911T Targa SOLD
Old 08-02-2007, 05:58 PM
Zeke's Avatar
I'd want to know more. What keeps the screw from moving?
Tyson once said you could static tune just about any MFI car by setting the part throttle adjustment 7 (or was it 8 ??) turns from the beginning. Trouble was, I could never find the "beginning". This would be good to know if one ever lost track of where he was. Start over.
Old 08-02-2007, 06:08 PM
Friend of Warren
Milt I have no idea what keeps it from moving. Although the screw is still spring loaded so maybe that is what keeps it in place. I heard the 7-8 turns out also. Never worked for me. Only thing that ever helped was getting a Gunson Gas Tester so I could see the results as I adjusted.
Kurt V
Old 08-02-2007, 06:18 PM
