al lkosmal's Avatar
69 - 71 MFI magstacks the same?
Does anybody know if the 69E and 71E used the same part number MFI magstacks. What's the part number for the 71E?
thx,
al
RGruppe #669
http://www.x-faktory.com/
Old 08-10-2007, 08:57 AM
andrew15's Avatar
Hi Al -
I believe that the stud spacing on the throttle body / stack interface was different. 69 had one spacing and 70-73 had another spacing.
That said, the stud spacing on the heads was the same so you could use a complete 69 throttle body/stack setup on a 71 or vice versa.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 08-10-2007, 09:21 AM
al lkosmal's Avatar
Andrew,
thanks. Do you know of a source that lists the part numbers?
al
RGruppe #669
Old 08-10-2007, 09:27 AM
1972_911T's Avatar
You can tell the 69 stacks because they are the only year to use a 901 pn all the later ones had a 911 pn.
Some good info here MFI Induction Chart
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 08-10-2007, 09:33 AM
