SC tempostat motor wire location?
I am looking for the white/green and green/brown wires that connect to the tempostat motor for the cruise control on a 1980 SC. The motor is gone but everything else for cruise control appears to be there. The wiring diagram shows the connection to be at T2k but I am having trouble finding out where T2k is exactly located. I have a feeling it is under the rear regulator panel but before I take that out and start looking, has anyone else seen these connections. Thanks.
Old 08-12-2007, 09:20 AM
sjf911's Avatar
Below are two pictures of the cruise-control connector bundle coming off of the cross-member wiring harness.
This is the chassis to engine harness bundle exposed (behind fuse/relay panel) with no evidence of the cruise-control wires. It appears the wiring harness splits close to the fire-wall.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 08-12-2007, 10:06 AM
sjf911's Avatar
sorry, this photo did not appear to load.
Sapere aude
Old 08-12-2007, 10:08 AM
Thanks, Steve.
Old 08-12-2007, 02:03 PM
I poked around and have not found anything yet. I noticed that in the chassis to engine harness photo, it appears to show a white/green wire in the harness that looks like the same white/green wire at the cruise control connector. Is that correct? Thanks.
Old 08-12-2007, 04:12 PM
sjf911's Avatar
Looking through my old photos, that wire appears to be in the bundle that goes to the left rear external lights and appears to be a much larger gauge than the tempostat motor wires. The plastic connector shown above appears to correlate to the T2k in the wiring diagrams. As I recall, the tempostat motor has a pigtail connector.
The control unit for the cruise control is in the trunk so I assume the wiring comes through in one of the main wiring bundles via the fire wall. I can't trace my tempostat wires any further than the mid-line of the cross-member with everything in the way. There is a larger wiring bundle parallel on top the cross member that appears to include the right rear external light bundle and possibly the a/c and may be what the tempostat wires originate from.
Sapere aude
Old 08-12-2007, 05:06 PM
Thanks again, Steve. I will keep looking.
Old 08-12-2007, 05:16 PM
