beamonk's Avatar
Send a message via AIM to beamonk
3.6 conversion question
Guys, I am running the DME harness in the car. Do I nees to route the harness over the heater duct like next to the fuel lines or below the duct along the body seam?
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 08-15-2007, 03:04 PM
DW SD's Avatar
I ran mine over the top of the rear shock cross member and around the shock towards the rear. The bundle was between the body and the rear shock mount cross member. I had to use a prybar to create enough space between the crossmember and the rear seat firewall sheet metal.
Doug
1971 RSR - interpretation
Old 08-15-2007, 03:19 PM
Bill Verburg's Avatar
Here's a pic of mine
Bill Verburg
Old 08-15-2007, 03:31 PM
DW SD's Avatar
Bill fashion of doing it is nice. I already had a hole closer to the trans tunnel, so I routed mine to take advantage of the hole.
As always, a picture is worth 1k words.
Doug
Old 08-15-2007, 03:39 PM
beamonk's Avatar
I like bill's idea, but I have routed the wires through the shock tower area and drilled the hole below the torsion bar as per Timmons instructions. Should I run the harness like an A/C line along the seam or over the heater duct?
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 08-15-2007, 06:59 PM
