Throw it on the ground!
How's your A/C holding up this summer?
With what seems to be record highs all across the country this summer, I thought I'd ask how your A/C is doing and what you plan on doing about it (if anything). I'll start.
We've been in the high 90's for the past two weeks in Atlanta....hard to even go outside. Morning commute no problem as ambients are in the high 70's to mid 80's with vent temps in the mid 30's. Afternoon commute not as good but bearable - today it was 95 on the way home and I was getting consistent vent temps in the low 50's on the move and the mid 50's in stop and go. Going out to lunch and getting in a heat soaked car is a no-go ....... A/C is fighting a losing battle....vent temps in the 60's
My next step is to replace my evap (slight leak -oil found in drain puddle) with a Kuehl, re-seal the evap box, replace the expansion valve, replace the front condenser with a Rennair desert duty unit and add a procooler. I've already added three puller fans on the rear condenser and one in the footwell at the intake and think they help a lot.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 08-15-2007, 04:15 PM
scottb's Avatar
Mark: The key to improving the a/c is increased condenser surface. Many people (myself included) have added an additional condenser/fan combination in the front left fender area; replacing the washer bottle and vapor recovery tank. Others have added underbelly and rear fender condensers. (Do a search and you'll find threads on both of these upgrades.) While replacing a leaky evaporator and installing a ProCooler (or a home brew subcooler) will help, if you want cold a/c (in the mid to upper 30s), you're also going to have to increase your condenser surface.
1984 Targa
Old 08-15-2007, 04:26 PM
I know you're right, but I've got to fix my 20-yr old technology first....evap, front condenser and one hose are orig and have got to go. If not happy after these changes, adding more condenser area will be next.
Planning on doing the install work myself.
Your A/C comments always appreciated.
Thanks!
Mark
1987 911 Coupe
Old 08-15-2007, 04:48 PM
burgermeister's Avatar
I took the compressor out when it was time for a valve adjustment... since the system held charge for about 3 seconds, I didn't bother putting it back in. Bracket left the car last week, as I had to replace a cam oil line under the bracket... I'm good with both windows down ("dual 70" AC) up to 90 or 95 depending on humidity - as long as traffic is moving.....
When I get wealthier and older and less tolerant (38 now - some time to go), I'll put in one of thos rennaire kits or something else that pretty much replaces the stock system. Seems a perennial chore to keep the Porsche factory air going, while any 20 year old Chevy will run fine till the doors fall off...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-15-2007, 04:51 PM
scottb's Avatar
If you've got an original hose, then you're really wasting your time. The original hoses are designed to leak, and that they do. If I were in your shoes, I'd bite the bullet and add the additional condenser and fan at the same time you're doing the other work. The system will be open and it will be easier to do everything now, rather than piecemeal later on.
1984 Targa
Old 08-15-2007, 04:53 PM
scottb's Avatar
Actually, it's been about four years since I did my a/c upgrades (additional condenser, ProCooler, and new hoses), and my a/c has been fine ever since. The stock systems are a perennial chore, but once properly modified, they don't require any more work than, well, a 20 year old Chevy's a/c.
1984 Targa
Old 08-15-2007, 04:56 PM
How much hose fabrication work is required to add a front fender condenser?
The one remaining orig hose in my system that needs to be replaced is the return hose from the evap to the compressor...others were replaced last summer (OEM not barrier I think.....but my system holds a charge well)
Mark
1987 911 Coupe
Old 08-15-2007, 05:02 PM
Well everything was going good until last week when I discovered a small leak on the rear condenser on my 930. If anyone has one that they don't need please let me know. Thanks
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 08-15-2007, 05:42 PM
I think we've just been in totally different 20 year old Chevys. Maybe it's the difference between 20 years of Michigan and South Carolina weather.
Old 08-15-2007, 05:45 PM
scottb's Avatar
Mark: IIRC, I simply installed the new condenser "in series" with the existing front condenser. What this means is that the hose that originally went to the input side of the existing condenser went to the input of the new condenser, and then I had a hose fabricated to go from the output of the new condenser to the input of the existing front condenser. Also, IIRC, I didn't shorten the hose that originally went to the front condenser. I think I looped it back to the new condenser, so no changes were made to the existing hose.
So to answer your question, if I'm remembering correctly, the only hose I had fabricated was the hose from the new fender condenser to the existing front condenser.
1984 Targa
Old 08-15-2007, 05:54 PM
scottb's Avatar
Now's the time to upgrade to one of the high performance condensers. I think www.retroair.com and www.griffiths.com sell them.
1984 Targa
Old 08-15-2007, 05:58 PM
TibetanT's Avatar
BMAN:
I happen to have a rear condensor and A/C compressor from a 1978 911SC. Will that work/fit in your 930?
Let me know.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-15-2007, 05:59 PM
scottb's Avatar
Ed: The 930 has a large condenser. Your 911 condenser is likely much smaller.
1984 Targa
Old 08-15-2007, 06:04 PM
IIRC, folks have had some decent results with the Pro-Cooler set-up. Just wish there was a kit for the 964.
Old 08-15-2007, 06:40 PM
TibetanT's Avatar
Scottb:
That's what I thought...too small.
Thanks.
Ed Paquette
1983 911SC
1987 944S
Old 08-15-2007, 06:42 PM
Originally Posted by TibetanT View Post
BMAN:
Let me know.
Thanks, but no it needs to be from a Turbo car. The turbo cars have a smaller one due to the intercooler. This is the one I need,
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 08-15-2007, 06:46 PM
scottb's Avatar
Do a search for posts by Jim Sims and Hugh R about the "home brew" subcoolers they've installed on their cars. Jim sourced the parts and explained how to install it. My guess is you could build one to fit your 964.
Also, have you contacted Ron Maxwell at Rennaire to find out if the ProCooler can be adapted to a 964?
1984 Targa
Old 08-15-2007, 07:52 PM
jhubs's Avatar
Mark, I followed your lead and added a pull fan to the rear condenser. Here are some photos of the work completed today. The SPAL fan is a 7.5 inch and pulls 440 CFM through the condenser and into the engine compartment. The fan is very close to the engine air intake so I figure I now have a 3.2 TURBO!!
Right side wiring:
Left side wiring:
I still have the R12 system and I had one of the hoses on the right side of the condenser replaced as it was rubbing on the engine deck lid hinge and leaking. Our temps in Colorado have been consistently in the mid to high 90's all summer. Global Warming?!!???! We have what some people call "dry heat" here in Colorado but HOT is HOT. I'll post some other AC modifications. So far I have about $500 invested.
Your previous posts about your AC improvements inspired me, so THANKS!
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 08-15-2007, 09:13 PM
Detached Member
Hugh R's Avatar
I did the Jim Sims subcooler for something like $20, plus the cost of twos, additional hose. Instead of one hose from the front condensor to the evaporator, you need one to the subcooler from the front condensor and another from the sub to the evaporatorand the same thing back from the evaporator to the compressor. Makes sense if your going to make all new hoses. Add in an additional 200 or so bucks for that. Do a search on Jim sims subcooler and you'll find it in one of the threads along with where he (and I) ordered the subcooler. You'll need to silver solder or braze in a couple of compression fittings from Home Depot. After soldering, pressure test it in a bucket of water to check for leaks. You can use your air compressor set as high as possible. You can only use compression fittings, the o-ring ones from an A/C shop won't work they're made of aluminum and you need brass to solder. It does essentially the same thing as the rennair system, in that it (I think) scavenges the last little bit of cooling out of one side of the system and transfer it to the other side of the system. I'm being a little cagey here, cause I don't have my notes on what I did in front of me. I'm traveling.
Hugh
Old 08-15-2007, 09:18 PM
scottb's Avatar
Wow...it looks like the fan is really close to the air intake. Are you at all concerned that it might restrict airflow to the engine?
1984 Targa
Old 08-15-2007, 09:19 PM
